Quantcast Enhance uncompressed 320x240 digital video - Page 2 - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Restore, Filter, Improve Quality
03-23-2010, 02:26 PM
1Ross 1Ross is offline
Many thanks
03-25-2010, 05:14 PM
For some reason, my version 6 install of this program stopped working. I get an error message. I'm having to contact OnOne about a solution. You're somewhat on your own, for the detailed settings -- I can't see it screen for screen.
What you're supposed to do next is open Photoshop, and then load the Genuine Fractals batch mode
You'll want to resize everything to 72dpi at 720x576 resolution. Save the images to a new folder. Save as PNG or Targa. Let that run for several hours, I'd imagine.
When Genuine Fractals is done...
You'll want to load the images in VirtualDub. All you have to do is load the first image of the sequence, and VirtualDub 1.9.7 is smart enough to know you're going to merge an image sequence into a new video clip.
You'll need to set up the video completely, including the framerate.
The video compression... (HuffYUV is my suggestion, or just used uncompressed)
and then export your video.
I'll assume your video project is muted -- no audio -- as was the sample you had given me.
What you do with the uncompressed/lossless AVI depends on your needs. It can be encoded to a DVD (high bitrate suggested), or an H.264 MP4 -- whatever you have to have. However, it should be noted that those are compressed video formats, so further image degradation may occur. Ideally, you want to keep the uncompressed version for your archives -- maybe even get the lipreader to work on this higher-grade file.
Sorry for the length of time it took to reply to this -- hopefully you won't run into the same issues in Genuine Fractals 6 as I did. I need to try it on another system some time.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
11-12-2010, 10:24 AM
Hi,
I have had limited success with the lip-reader and was wondering about the "forensic-type methods" you mentioned.
Any chance of imparting one or more of these methods to me?
11-14-2010, 11:14 PM
Have you considered locating another lip-reader?
I would have to say that you'll probably have to use the same type of professionals that governments do (i.e., reading lips of terrorists in the background of videos). You see this type of thing on TV shows like NCIS and CSI, but it exists real-world, too -- without all the special effects and fake "enhancement" filters.
That will set you back a few dollars, no doubt.
For example: http://www.lipreadingtranslation.com...nscription.htm
You could also contact a well-known forensic media specialist, and ask for his opinion on locating a good lipreader.
For example, asking Larry Compton: http://media-geek.com/index.php?opti...d=1&Itemid=186
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
03-20-2011, 02:56 AM
Site Staff / Owner and Editor
I wanted to share a pair of updates I received via email from 1Ross:
I also wanted to thank you guys for the professional help you've given me and to let you know that in the end your excellent advice led me to a UK based company called Best Evidence Technology Ltd.
I would like to recommend a service for review that I have personally used in the past month that has been stunningly good in every respect (including price).
They are a UK based company called Best Evidence Technology Ltd
Michael (michael.hartshorne@bestev.co.uk) from Best Evidence has 16 years experience and used MotionDSP's Ikena software to produce stunning results at a reasonable price.
I would like to enquire firstly if you would give him publicity through a review of his services as I have used several companies and he has by far produced the best result and secondly whether you would feel it appropriate for him to advertise his services on your site.
I've encouraged him to come here when he has time, and give us the full details on how his project turned out.
__________________
- Thanks for visiting! | Advertise on The Digital FAQ | Upgrade to Premium Member
Capturing Video from my Digital Camcorder kabal2000 Capture, Record, Transfer 5 10-12-2010 01:01 AM
How to remove timecode from digital video? lounisproduction Restore, Filter, Improve Quality 2 08-20-2010 10:38 AM
Bypassing MJPEG hardware for uncompressed AVI lyrxtig Capture, Record, Transfer 1 07-24-2010 02:01 PM
15% off (OR free digital kit with) the best digital scrapbooking software admin Photography - Coupons, Sales and Deals 0 06-22-2010 01:20 PM
Improve quality of digital 8 video klassal Restore, Filter, Improve Quality 3 12-10-2009 02:11 AM
All times are GMT -5. The time now is 04:28 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
