Started to using 8710 ...for it first time and very strange results.
Let me give an example -
VHS tape has an opening sequence of black, then some title text, after about 10 sec , a then second title screen, followed 10sec later by gradual fade in of video.
If I play the tape .. this works fine.
When I digitized it without TBC .. i.e just through ADVC300 - fine
However when I digitized today with the 8710 in the path, the resulting capture has the first title screens OK, but when the second screen comes in the first stays .. so ends up with a text overlay mix.
If I look at frames individually they are correct, but when I play the DV file its screwed
.. weird ?
The rest of the video seems to have captured OK
but see no improvement over ADVC300 on it's own.
Thinking it was something stupid
I cleaned video heads, and ran capture again
same thing?
Is there something I need to do here
.. could there be interaction between 8710 & ADVC300 ? or is it something else?
Do I need to turn anything off on the ADVC300 ?
There is certainly something weird going on ...
Here is an output screen grab which shows the problem Scene 1, Scene 2 and the output which has merged them ..
While creating screen grabs I noticed another weird thing that I guess is related
I assume to interlacing.
I took the same 'merged' screen grab and resized it ... when I resize it by 50%the overlaid text disappears... nothing special just a simple 50% resize in paint.
