03-22-2010, 06:55 AM
MrSupergolfer MrSupergolfer is offline
Hi,
I have a clip that has big issues:
http://www.sendspace.com/file/4ak4e3
This comes from vhs recorded with dvd recorder. Looks like the problem is ghost.
Is there any way this can be improved in virtualdub or whatever?
03-22-2010, 03:58 PM
I'm adding the attachment to this post. It's small enough to be spanned across two RAR files.
Will reply with suggestions soon.
03-22-2010, 07:52 PM
I don't know that this can be fixed.
It's not a simple ghosting issue, this was a problem from the original broadcast -- poor antenna reception, if I had to guess. (Maybe bad cable reception?)
This isn't the typical luma/chroma shift, or even electronic interference ghosting. This is more like a double exposure. I'm not readily away of a method to fix that -- I've never come across it in a project.
Motion Problems on Recorded DVDs... deter Restore, Filter, Improve Quality 2 08-18-2010 09:46 AM
JVC DR M10-Dvd Recorder PROBLEMS! MagnificentMarcus Capture, Record, Transfer 17 05-19-2007 05:13 AM
Having problems with lite on dvd recorder ty3 Videography: Cameras, TVs and Players 2 08-16-2006 12:27 AM
JVC DR M10 DVD recorder problems!! MagnificentMarcus Blank Media 7 01-10-2006 03:49 PM
DVD Recorder, recording problems... help!? emokid Capture, Record, Transfer 11 06-15-2005 05:00 PM
