Quantcast Cleaning up a dvd - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Restore, Filter, Improve Quality
06-21-2005, 11:16 AM
Wineslurper Wineslurper is offline
Hi everyone. This is my first post so please be patient. I have some dvd's that have were captured from vhs(not by me nor do I have the tapes).I am using procoder. I have used dvd decrypter to rip the .ifo and 5 vob files from the dvd. Decrypter read the disc as sony dvd recorder if that helps. Anyway I loaded the 5 vob files as source and selected dvd as target, selected some filters to clean things up and hit convert. Well it runs all night and is still not done. Its a 1 hour show on the dvd. I did not select stitch. There is some color and noise issue to clean up and I think I am doing ok there. I stopped it and burned what I had done and it looked better but no sound. I am thinking because I stopped the program. Thanks
06-21-2005, 12:01 PM
Procoder is good software, excellent encoder engine.
The filters are decent. It will work.
The sad thing is that the options to improve video are dimished once you convert the analog digital. It would have been best to restore them in the analog realm. But what's done is done.
How fast a computer encode is based on how many filters are in use, as well as the speed of the processor.
The sound is converted after the video, so yes, that is why there is no sound. Or it least could be. Procoder can only read so many audio codecs, so be sure it shows as being read in the source window.
Edited by: admin
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
06-21-2005, 12:07 PM
2 filters. 2.8 AMD with 1 gig ram.
06-21-2005, 12:10 PM
Procoder usually gives a estimatesd completion time. Even with a LOT of filters, I don't see how it could take longer than 12-18 hours at most.Edited by: admin
__________________
Help cleaning up vhs. Konfusion Restore, Filter, Improve Quality 7 02-08-2009 11:56 AM
Dropouts, Cleaning and New VCR mrwhitethc Restore, Filter, Improve Quality 1 07-26-2008 06:53 AM
Laser cleaning kits? SavageAmusement Home Entertainment and Videography 3 10-02-2006 06:33 AM
What hardware for restoring/cleaning video ? couldbe Restore, Filter, Improve Quality 3 03-16-2004 03:42 PM
All times are GMT -5. The time now is 04:38 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
