08-12-2010, 10:11 PM
cyber-junkie cyber-junkie is offline
The movies, usually tv stuff that has the blurry blocks covering something "they" don't want you to see, sometimes nudity, can these be fixed or eliminated or is the error I will call it permanent?
08-13-2010, 05:01 PM
It's part of the image, and it replaced what used to be there.
So no, there's no way to remove it. It's a permanent part of the video now.
08-15-2010, 03:48 PM
Ok, what is this? how is this done? I have seen this quite often on cable tv.
08-15-2010, 06:53 PM
A translucent image or filter is superimposed on top of the video, generally in non-linear post production, although it can be applied live during a delayed broadcast, using the high-end editing facilities.
If the person is moving, it's tracked along that path.
(I forget the technical video jargon used for this. I'll probably wake up at 3 a.m. randomly having finally remembered it.)
It's a pretty basic editing task.
The new video output is forever changed. The only way to have an "uncensored version" is if a live broadcast dual records an uncut version, or if the source of the non-linear version is retained. But in each case, it's a separate video that is uncensored -- the censored version cannot be reversed.
08-15-2010, 09:14 PM
That sucks...was hopeful it was an error that could be removed.
08-19-2010, 03:49 AM
robjv1 robjv1 is offline
Is this something you wanted to try for fun or is this footage that is unavailable otherwise?
08-19-2010, 12:19 PM
I'm curious how that would make a difference?
Either way, the original uncut video is gone. The blur is not on a layer that can be removed, but simply replaced whatever used to be there. A pair of big bouncy tits, for example, are now a pair of fuzzy blocks. There's no way to take off the "fuzzy digital bra". Think of it as a "fuzzy blocky tattoo" that has forever changed what was once there.
Maybe you meant having fun doing the inverse? Adding censorship?
To do this in Premiere, watch the Wrigley Video guide: http://wrigleyvideo.com/videotutoria...o_blurface.htm
Wrigley has some great Premiere guides. I've used many of them, and can help if you have any questions. Just open new threads on the appropriate topics.
I've also attached the "blurred face" WMV in a pair of RAR files below, as a backup, if needed.
If you're not sure what to do with ZIP or RAR files, then read this help post.
To get access to download the files, simply join the forum as a Free Member (it's free!) and that's it.
File Type: rar Premiere-FaceBlur-Tutorial-WrigleyVideo.part1.rar (7.92 MB, 23 downloads)
File Type: rar Premiere-FaceBlur-Tutorial-WrigleyVideo.part2.rar (754.4 KB, 14 downloads)
How to remove audio static/buzz and hiss? lordsmurf Restore, Filter, Improve Quality 6 02-11-2022 03:51 PM
Converting Flash Movies (.swf) to .avi Magnus D Encode, Convert for discs 3 07-29-2009 04:53 AM
Remove DMR lock & convert cnickle1 Encode, Convert for discs 5 03-22-2009 01:11 PM
How can i remove black bar from side of mpg?? Konfusion Restore, Filter, Improve Quality 12 11-27-2007 05:04 AM
Remove text from pic, but leave background? manthing Photo Processing, Scanning & Printing 2 03-27-2006 12:47 AM
