05-02-2011, 06:54 PM
max_cady max_cady is offline
Full sized image + short clip attached.
Any suggestions are welcome!
05-02-2011, 10:17 PM
It looks like a film scratch.
There is a Descratch Avisynth filter, for cheap/free methods: http://avisynth.org.ru/descratch/descratch.html
Sample script:
AviSource("input.avi")
LoadPlugin("descratch.dll")
ConvertToYV12()
DeScratch(mindif=2)
Are you familiar with using Avisynth?
And then there's also some high-end software like Davinci Revival: http://www.blackmagic-design.com/pro...avincirevival/
Or Diamant: http://www.hs-art.com/html/products/diamant.html
A related thread can be found here: http://www.digitalfaq.com/forum/vide...ch-filter.html
05-02-2011, 11:14 PM
Thanks to reply!
Yes i'm familiar with Avisynth.And i try DeScratch before but dont work properly.
And some DeScratch scripts giving error like this
left=crop(0,0,-660,-0)
middle=crop(60,0,-644,-0).DeScratch(mindif=3,asym=12,maxgap=5,maxwidth=3,minlen=1,maxlen=576,maxangle=2,blurlen=25,border=0,modeY=3,modeU=0,modeV=0).destripe(rad=3)
right=crop(76,0,-0,-0)
stackhorizontal(left,middle,right)
05-03-2011, 04:24 AM
Remember to attach images, files, etc, to the forum: http://www.digitalfaq.com/forum/show...ages-1529.html
We try to avoid external sites for linking to images/etc. (As explained in instructions.)
I think you're making the script too complicated.
Is that something you wrote, or something you found on another site and did a copy/paste?
I would start with the default, as per the filter's manual:
ConvertToYV12()
DeScratch(mindif=2)
Notes:
  • Now, obviously you'll have to change AviSource to whatever your actual input method is. Do NOT use DirectShow input.
  • LoadPlugin is best with the full qualified file location. (C:\Program Files\Avisynth\plugins\etc etc etc -- whatever it is.)
  • ConvertToYV12 only if needed. (Again, depends on source.)
  • Use the basic DeScratch, see what it does at a default setting.
Tracking lines in video; how to fix these VHS tapes? deter Restore, Filter, Improve Quality 29 08-17-2020 01:28 PM
Vertical or horizontal for storing an external hard drive & best enclosures ? Sossity Computers 1 12-09-2010 07:26 PM
Ulead DVD Workshop PSD lines lordsmurf Author, Make Menus, Slideshows, Burn 3 03-14-2009 08:45 PM
Free THX Optimization DVD and Blue Glasses markatisu Videography: Cameras, TVs and Players 6 03-24-2007 04:04 PM
HD vs Blue Ray. Who will Win? wayshway Videography: Cameras, TVs and Players 5 02-02-2007 09:00 AM
