09-11-2011, 06:00 PM
Superstar Superstar is offline
I'm working on some homemade DVDs that I recently got, and so far on the ones I've gone through, the audio is already in AC3 format. However, a few of the DVDs still have hiss that I'd like to remove.
Since the audio is already in AC3 format, can I still restore that audio, or do I have to just keep it how it is?
If I'm able to restore the audio, how do I do that? I've only restored audio and then transferred it to AC3 format, I've never started with AC3 format, and then restored it.
09-17-2011, 08:05 PM
AC3 is just an audio format. Sure, it can be improved. Any audio can. The only issue is that AC3 is compressed, so it's often nor workable directly in editors. Like video, audio editors prefer to work with lossless or uncompressed audio files, such as WAV. So you'll want to convert the AC3 to WAV, then work on it from there.
I convert AC3 to WAV using Goldwave, because I have an AC3 codec installed in Windows XP. It's quicker than most other software. The freeware Aften converts to AC3, but I don't remember if it converts AC3 to WAV. It might. Same for BeLight. Avidemux can probably convert AC3 to WAV. I don't think Audacity opens AC3 -- it won't on my computers.
I edit in Sound Forge. Sound Forge 9 can open AC3 directly, though I still prefer to give Sound Forge uncompressed WAV files because the program works quicker without the decoding processes.
DTS audio file, unable to hear after authoring? manthing Encode, Convert for discs 3 02-12-2018 05:09 AM
SoundForge Audio Filter Presets Pack [DOWNLOAD] admin Restore, Filter, Improve Quality 22 02-24-2013 07:07 PM
Help fixing the audio file issue designunlimited Restore, Filter, Improve Quality 1 04-01-2011 11:36 AM
Your DVDs reviewed - Menu techniques, video/audio quality, and what else? kpmedia Project Planning, Workflows 0 07-05-2010 12:10 PM
How to Encode Audio to AC3 with Good Quality [GUIDE] lordsmurf Encode, Convert for discs 2 06-17-2009 10:10 PM
