10-02-2011, 04:51 PM
jrodefeld jrodefeld is offline
Hello,
I am having an extremely frustrating problem when I am running filters through virtualdub. At some point before completion (usually less than half way done) the process stops and gives the error, "Wrong FPU CW!". I have no idea what this means or what is causing it.
Could someone please tell me what to do with this? Thanks a lot.
10-02-2011, 04:59 PM
I see this same error mentioned on a Czech site. That person was able to simply 'X' the warning box and ignore it, and the video would continue to encode without flaw.
I've never heard of this error. I honestly have no idea.
Try to disable filters one by one, and see if the removal of any one specific filter allows it to continue. Just use the standard scientific method: process of elimination.
General average filtering advice for VirtualDub? cyber-junkie Restore, Filter, Improve Quality 8 04-11-2010 10:45 AM
VirtualDub - Can't Capture Video rckowal Capture, Record, Transfer 7 01-19-2010 06:49 PM
JVC filtering on SVHS VCR SR-V10 ramrod Restore, Filter, Improve Quality 4 12-24-2009 05:02 PM
Panasonic ES10 units for sale! (frame sync filtering!) lordsmurf Restore, Filter, Improve Quality 0 08-28-2009 03:30 AM
VirtualDub - frames inserted? lookouts Capture, Record, Transfer 3 10-15-2006 09:28 AM
