07-15-2012, 06:22 PM
Belmont Belmont is offline
What purpose does the Chroma Smoother tool in Virtualdub serve, exactly? Say, if you're exporting an uncompressed/HuffYUV .avi to encode in MPEG-2, wouldn't the MPEG-2 encoder already compress the color to the proper colorspace settings? I see subtle differences when playing around with it, but I just don't see the purpose of it. Can someone please enlighten me on this matter, or at least shed some light on this for me?
07-16-2012, 12:23 PM
Mpeg2 DVD is ycbcr (4.2.0) and huffyuv is 4.2.2 so there is a mismatch and you should use an avisynth script to fix that with accuracy imo such as:
mpegsource("blabla")
pointresize(last.width, last.height*2).converttoyv12(matrix="Rec601",interlaced=true).pointresize(last.width, last.height)
07-16-2012, 01:03 PM
Chroma Smoother is a restoration filter. It's chroma noise reduction (NR). It doesn't really have anything to do with the colorspace of MPEG or Huffyuv. It's not a reference to the same sub-topic of chroma.
Use it sparingly, otherwise you'll create "mouse trails" (temporal artifacts).
Good MPEG-2 encoders already properly convert the colorspace. I pretty much only use MainConcept Reference. Sometimes I'll use the Adobe Media Encoder, which is a MainConcept-based MPEG export from Premiere CS3 and CS4. Less often I'll use the free MPEG-2 encoding in Avidemux 2.5, but even that appears to be fine. I don't know that any special Avisynth work is needed when converting lossless AVI to MPEG-2.
I think themaster's script refers to importing MPEG-2, and then processing it.
@themaster1, welcome to the site.
07-16-2012, 03:55 PM
my fault i meant to type
avisource("blabla") #huffyuv 4.2.2
assumetff (or bff)
for vhs you'd need something more:
avisource("blabla") #huffyv 4.2.2
assumetff (or bff)
crop(0,0,0,-1).pointresize(width,height,0,0,width,height).mergeluma(last)
pointresize(width,height,0,1,width,height).mergeluma(last)
I have tested this on a smpte test pattern
07-16-2012, 09:43 PM
@themaster1: Be sure to put Avisynth scripts in the [code][/code] bbcode boxes.
07-19-2012, 01:20 AM
Actually, looking back at this, I was thinking of the temporal smoother filter's function, not this one. The temporal smoother only does temporal NR, too, not chroma NR. I just thought this was the chroma version for some reason. (I was tired, probably.) I don't even have the Chroma Smoother filter installed, because it's pretty much useless in my opinion. It's never used.
What are VHS Chroma Flaws? How to Fix Them? lordsmurf Restore, Filter, Improve Quality 4 07-17-2018 06:21 PM
Virtualdub and chroma interlacing unclescoob Restore, Filter, Improve Quality 6 10-25-2011 11:12 AM
Is there a m2v loseless cutting tool? manthing Edit Video, Audio 1 06-15-2011 05:35 PM
FOR.A brand TBC FA-800A, chroma cleanup? deter Restore, Filter, Improve Quality 2 01-15-2010 04:29 PM
Best tool to beef up sound? manthing Edit Video, Audio 5 03-30-2006 05:12 AM
