10-19-2012, 03:42 PM
DeeSeven DeeSeven is offline
Hello,
I have an old episode of NOVA that I ripped from a vhs tape (no longer have the vhs tape). I'm testing out virtualdub and some filters to clean up the video. The video isn't that rough (for its age) but there is just this fine "line of fuzz" on the bottom of the picture that I can't manage to filter out. I tried to use manual tracking with the vhs tape but it still wouldn't go away. Is it even possible with virtualdub to filter that out? or should I use avisynth?
I have included a screencap so you can see what I'm dealing with.
10-19-2012, 08:21 PM
I've seen worse and it's normal to have that "line of fuzz" at the bottom . The only option is to crop and add black borders.You crop about 8 lines and you add borders 4 top - 4 bottom.
If you want more help to clean the whole frames post a video sample. I can see chroma noise green/pink horizontal lines
good luck
The following users thank themaster1 for this useful post: DeeSeven (10-21-2012)
10-23-2012, 10:47 AM
Take a look at this post: http://www.digitalfaq.com/forum/vide...converted.html
While there are some methods to truly remove that noise, instead of just mask it, there are side effects that can lower the quality of the interior image.
So it's still best to mask.
The following users thank admin for this useful post: DeeSeven (10-23-2012)
10-23-2012, 12:55 PM
juhok juhok is offline
good luck
It's better to add 8 to the top or bottom instead of 4/4 to optimize for compression - for example MPEG2 macroblocks consist of 8x8 pixels and you should align sharp edges to block boundaries.
The following users thank juhok for this useful post: DeeSeven (10-23-2012)
10-23-2012, 01:10 PM
thanks for the advice, I've uploaded a short clip below
10-23-2012, 01:12 PM
I apologize for the double post but i have a 10 second clip of the actual episode versus the intro which is what is above
10-23-2012, 07:45 PM
For both clips you can try this script which gives you this
After that or perhaps before you may want to deshake this video a little (vdub's deshacker comes to mind)..i haven't bothered
The following users thank themaster1 for this useful post: DeeSeven (10-23-2012)
VirtualDub with Filters Pre-loaded + HuffYUV [DOWNLOADS] lordsmurf Encode, Convert for discs 50 01-01-2024 09:54 PM
How to remove subtitles hard-coded into video? Best delogo filters? jairovital Edit Video, Audio 5 01-02-2017 08:06 AM
Deinterlace NES gameplay video with VirtualDub filters? DV vs Huffyuv for games? JLegnon Project Planning, Workflows 15 05-29-2012 09:40 PM
VirtualDub is not able to detect a capture card / line in? Mejnour Project Planning, Workflows 0 04-27-2012 03:23 PM
Line noise, AVR, EMI/RFI Filters, Ground Loop Isolators. Confused Tuco Capture, Record, Transfer 1 04-28-2011 06:25 AM
