10-24-2012, 03:27 PM
DeeSeven DeeSeven is offline
title says it all, I can get the vcr for around 70 shipped to my house. I think it would be a good "first model" for someone with limited vcr experience as it isn't $200-800 and it would be a step up from the model I have now. But in my readings I've found that most vcrs need a remote as it holds functions that aren't on the actual vcr unit itself. So does this need a remote?
10-24-2012, 05:28 PM
ive had a few of these, they are much better than the average consumer VCR.
but i still would not use one to do tape transfers as they lack a TBC
you wont need a remote
these unit have an hour meter - ask the seller how many hours are on it.
if it is alot i wouldn't bother with it.
The following users thank volksjager for this useful post: DeeSeven (10-24-2012)
10-24-2012, 05:42 PM
thanks for the info volksjager, hm after looking at standalone TBC I think I'll go with a vcr that has a built in TBC as 400 is way out of my price range lol.
10-24-2012, 05:46 PM
you need both - they serve different functions
you can get a decent TBC JVC and a standalone TBC for under $200 each.
10-24-2012, 05:49 PM
oh? so I need a standalone TBC and a vcr with TBC gotcha..good to know I'll keep my eyes peeled
10-24-2012, 05:57 PM
if you want the best quality out of you tapes you need both as well as either a good capture card or a LSI chipset DVD recorder.
there is an HR-S7900U on ebay right now
10-24-2012, 07:34 PM
alright looks around my price range, what about a TBC? does it matter if I get one that is older? I've been searching around ebay and they have a ton of them.
10-24-2012, 07:40 PM
try looking for an AVT-8710 or a Datavideo TBC-1000
i use a KeyWest BVTBC-10 - which can sometimes be found cheap.
there is also a BVTBC-8 which is good
avoid the original BVTBC (no hyphen and number)
also very good one that is hard to find is a For-A FA-125
dont use those old big clunky broadcast TBC's.
Converting SVHS videos and later SVHS decks Jpass9992 Capture, Record, Transfer 10 08-21-2015 02:41 PM
Partners Required for Wedding Photographer ankushd Photo Cameras: Buying & Shooting 2 03-01-2014 02:01 AM
JVC SR-S365U Service & User Manual [DOWNLOAD] LukeS Video Hardware Repair 1 10-20-2011 03:30 AM
Panasonic AG-1980 playing non-SVHS as SVHS? cyber-junkie Videography: Cameras, TVs and Players 15 04-21-2010 03:48 PM
External DVD recorder - is USB2 required ? stoogedog Computers 7 02-27-2008 02:44 PM
