CTB-100
anyone use this device? or anything similar?
here's the blurb about it : Make copies of your video without noticeable signal loss or noise. Now you can correct and unstable video source before you make copies. The CTB-100 is a digital full-frame synchronizer that replaces all sync signals from the source. The result is clean transfers and clear copies. CTB100 Features: Restores vertical and horizontal sync and colour burst. Eliminates picture jitter - ensures stable image. Adjusts Colour, Brightness, Contrast, Sharpness 7 NTSC Tint. NTSC, PAL, SECAM. Built-in AGC function ensures 1 Volt p.p. outputs. CV and S-Video in/out. 400 line resolution. Input TV Systems: NTSC 3.58, NTSC 4.43, PAL, PAL-M, PAL-N, SECAM Connection Terminals: Video Input: 1 x Composite 1xS-video input Video Output: 1x Composite, 1 x S-Video Sampling Frequency: Y: 13.5MHz R-Y: 6.75 MHz B-Y: 6.75MHz Digital Code Bit: Y: 8 bits R-Y: 8 bits B-Y: 8 bits Processing Controls: Contrast, Bright, Colour, Tint, Sharpness. Correction Range: Full Frame TBC Frequency Response: 400 lines S/N Ration: 50dB Memory: 6M bits Power supply: DC 12V 1A. Weight: 1Kg. Accessories: DC adaptor is this a good device to use to basically stabilise my vhs source? |
It's a TBC. It's the European version of the AVT-8710
