01-25-2013, 01:53 PM
Mejnour Mejnour is offline
Hello guys,
I would like to know what should I do when I see a difference in color at the acquisition vs lecture of the same video? I took a snap shot of the difference of color I get! I use virtualdub 1.9. At least playing with media player or virtualdub give the same result.
Maybe my acquisition settings are wrong! I am a bit lost with what is important and what is not with during acquisition.
Here my settings
Video Color depth
Decompression format = Autoselect
output format to compressor/display = 4:2:2 UYVY (why not YUY2?)
video compression
Huffyuv v.2.1.1 Multi-Threading (I have a PC-DL deluxe motherboard)
Video
Full processing mode (or Direct stream copy or fast recompress or normal recompress)
Audio
Direct stream copy (or full processing mode)
Option
Sync to audio
01-26-2013, 12:16 PM
Originally Posted by Mejnour View Post
Hello guys,
Found my color problem, got to Options/Preferences/Display "uncheck" Use DirectX for display panes!
If I can get input for my settings would be nice...
01-26-2013, 02:28 PM
Yep. You beat me to it. By default that nuisance setting is turned on.
The following users thank kpmedia for this useful post: Mejnour (01-26-2013)
01-26-2013, 05:11 PM
About the "huffy configuration dialog"
If I understand this codec; the 2 windows "YuY2 compression method" and "RGB compression method"
mean that we have 2 choices for compression YuY2 or RGB? Correct! But do we have really the choice?
It sound like a dumb question but what determine wich one will be chose by default since they are in 2 separate windows? I know that I am missing something...
Huffyuv know itself just by the input?
I mean if I feed the video card with a VHS tape, he will automatically use YUY2 to compress?
If I use a DVD he will automatically use RGB to compress?
01-26-2013, 06:21 PM
by default it's set to encode in yuy2 otherwise you must enable the option "always output rgb" i believe if you want rgb
The following users thank themaster1 for this useful post: Mejnour (01-28-2013)
01-28-2013, 10:01 AM
Seem logic I guess
anybody else can confirm please?
01-31-2013, 01:22 AM
Here! I can confirm.
The following users thank kpmedia for this useful post: Mejnour (01-31-2013)
VirtualDub reported CPU usage not matching Windows Spektre Capture, Record, Transfer 2 01-14-2013 09:52 PM
Problem with Virtualdub when filtering... jrodefeld Restore, Filter, Improve Quality 1 10-02-2011 04:59 PM
Green in picture even after desaturation / Problem with monitor color? manthing Photo Processing, Scanning & Printing 10 06-19-2011 04:05 PM
JVC HR-S9911U picture color fade problem. gzmachine Video Hardware Repair 7 03-05-2011 10:14 AM
How to remove redness from picture - Fix color cast or tint problem admin Photo Processing, Scanning & Printing 1 01-23-2011 05:44 PM
