Is Datavideo STC-100 a good integrated TBC?
Hi guys,
Looking for the Tbc on the web I run into the Datavideo STC-100 that is an Ntsc/pal converter with integrated Tbc (or that is what I understood :D)! Is it good used as Tbc? Thanks |
No.
Both the DataVideo and Cypress (AVToolbox) format converters only work when the signal is being switched. PAL > NTSC = TBC on NTSC > PAL = TBC on PAL > PAL = TBC off NTSC > NTSC = TBC off The TBC cannot be controlled. It's only enabled when the formats are being converted, not when the signal is be played straight though. This was a stupid design choice. |
Ah what a pity!:(
It could be useful separately controlled! |
