01-14-2006, 04:30 AM
Tom_n_Jonna Tom_n_Jonna is offline
Hi guys...yet another question.
Here's en equipment description. I have a PrimeImage TBC/Freeze II, model. Its funtions include video, setup, and chroma/advamced chroma level adjustments, Auto Gain Control, Hue, selections between field and frame freeze, low and high level detail enhancement. Y/C delay, field/frame strobe, rate of strobe, horizontal and burst phase, and a comb filter.
OK, now I'm trying to transfer some VHS-based stuff to DVD. My VHS stuff is all copy protected (like Disney stuff).
My problem that it appears the TBC isn't overcoming the copy protection. When I play the video through the TBC the screen jumps sporadically. Each time it jumps, the field freeze indicator light comes on.
How can I overcome this? PrimeImage is supposed to be some pretty good equipment.
Look forward to hearing back.
Tks...Tom
Cheers...Tom
01-20-2006, 02:18 PM
cp32 cp32 is offline
videostabilizer will fix that. removes macrovision from Disney tapes too.
I recommend the RX II . I ve had nothing but good luck with mine.first one lasted 8 yrs. It runs on a 9 volt battery. usually cost 30 -40 .00
Works with most dvdrecorders too ,except zenith . Easy fix there. Vhs to vhs then to dvd ( wink).
Recorders I do it works with. which I ve rented in the past :
Philips
Panasonic
sanyo
01-20-2006, 02:38 PM
tek tek is offline
It also works with RCA. I can personally vouch for that one!
01-21-2006, 12:39 AM
Wow...Tks Guys!!
Cheers...Tom
Frame rate trouble in DVD Architect Reading Bug Encode, Convert for discs 15 12-31-2009 01:39 PM
Trouble with v1900 AIW, ATI shut itself down? Tom_n_Jonna Capture, Record, Transfer 2 06-21-2007 08:51 PM
Question concerning tv problem trouble shooting stoogedog Videography: Cameras, TVs and Players 2 08-03-2006 03:20 PM
Having some trouble... Daniel Capture, Record, Transfer 9 06-06-2005 10:25 AM
Having login trouble? (IE5,IE6) Here’s the fix... admin General Discussion 0 04-19-2004 03:32 PM
