Suggestions for improving my home videos? (Avisynth, VirtualDub)
Hi all,
Glad to see these forums are still active (and that smurf is in good health!), I originally registered in 2012 to tackle a huge home video conversion project and it took me until this weekend to finally get around to it :laugh: My capture workflow for each of these videos is as follow JVC HR-S7800U & JVC-HR-S7600EU (for PAL vids) --> TBC-1000 --> ATI Wonder 600 USB. I also have a TBC-4000 but could not find the power supply for it. I followed Sanlyn's Virtualdub settings guide. The only settings I modified before capturing the videos were the brightness/contrast settings while viewing the Histogram in order to keep the videos within acceptable levels. I believe the videos were first recorded on a 1992 Hitachi VM-E31A 8mm video camera then transferred to various PAL and NTSC VHSs. I am ready to touch up and improve the home videos, but I am a bit lost on where to begin for each video. I have most of the recommended plugins for Avisynth & Virtualdub, but have never used Avisynth before nor any of the plugins in Virtualdub. Looking to fix: -Chroma (dull colors & color bleed) -Blurry Videos (would like to sharpen if it is recommended) - Most noticeable in the 100 Hunt video -Masking Borders & fixing horizontal tears - All videos -Audio Hum and clicks (will do last via audacity after visual restoration) - Most noticeable in the 1993 & 1994 videos -Any other issues you may suggest fixing Some videos are compilations of different scenes that are not related and have different scenery. would it be suggested to cut the videos into the different scenes and then modify them? I have 4 main videos that I would like to begin with. I have uploaded multiple clips per video as examples of each capture. They are located at the link below and available for download. Note that the 1996 video is a PAL video. https://drive.google.com/open?id=0B5...HhCRS15LVJPWTQ I would really appreciate some suggestions on where to begin for each video, or maybe a general AVsynth script that I could get more familiar with. Looking forward to learning some new techniques and to improving these videos :D Thanks! |
Avisynth, change C/L as needed (vertical, horizontal, 2px at a time, - or +) Code:
ChromaShift(C=2, L=-8) # align chroma over luma Quote:
Fixing tearing done in ES10 or ES15, in hardware, pre-capture. Aside from that, masking it is all that can be done once digitized. A VirtualDub masking guide stickied here. Quote:
Note: Sometimes Amazon has boxed versions of 9 for cheap. Quote:
That help some? :salute: |
Thanks for the swift response! Seems that I have a couple of items confused, thanks for the clarification.
I have converted the big files and chose 1 clip from each video and uploaded them here. The original folder with all of the AVI clips is still available here. Here are some of the issues ive noticed with these clips. I would appreciate any other suggestions to improve them as well. Blurry Video Need general suggestions for this one Screen tearing on top Audible clicking disrupting the audio + Hum General suggestions Thanks :) |
Thanks for all the samples! Plenty to think about.
First. allow me to offer a capture tip and suggest how to make uploads easier: 1. I'd advise against using HuffyuvMT for capture. It's long obsolete and isn't as well optimized for multi-core CPU's as newer versions. Note that multi=threadiug and multi-core are two different things. huffyuvMT preceded multi-core by a good stretch and was not as efficient as older non-MT versions. The preferred huffYUV is here: https://www.videohelp.com/download/huffyuv-2.1.1.zip. You can keep hyuffYUV and huffyuvMT both loaded in your system at the same time without conflict for compliance with old and new huff captures. 2. You might already be aware that most of your samples were uploaded as uncompressed RGB. Converting to uncompressed RGB from the (supposedly) original YUY2 Huff files increased the size of each file by 300%. I recompressed the three 1994 samples using the later huffyuv (non-MT), then recompressed them again as working files using lossles Lagarith YUY2, which many use as a working compressor because it accepts RGB, YUY2, and YV12. I use huffyuv for capture because it's easier on a CPU during capture. On occasion you'll have to process files in YV12 because of certain filter requirements; in that case I save those working files as lossless Lagarith YV12 (Note that encoding to MPEG or h.264 produces a YV12 file, but more complex colorspaces like RGB and YUY2 are used to help maintain chroma resolution during intermediate processing). Here's a file size comparison after I recompressed the 1994 samples: uncompressed huffyuv Lagarith Lagarith File RGB YUY2 YUY2 YV12 ---------- ------------ -------- -------- -------- 1-1994.avi 613.3 MB 208.0 MB 182.4 MB 157.7 MB 2-1994.avi 268.9 MB 76.1 MB 67.1 MB 56.4 MB 3-1994.avi 131.4 MB 45.5 MB 37.3 MB 32.0 MB The collection of four 1991 samples totaled 898MB when unzipped as uncompressed RGB. When recompressed to lossless HuffYUV YUY2 the total size of the collection was 264MB. Converting to RGB before addressing levels, noise, and other glitches in the original YUV interferes with many cleanup operations, besides making it impossible to try clearing up some detail lost by clipping during YUV->RGB conversions. Many chroma and noise problems are best addressed in the original colorspace. In the experience of many users, colorspace conversions are more cleanly and safely handled in Avisynth than in most editors. Jumping back and forth in colorspaces isn't recommended due to quality loss after a series of math rounding and interpolation errors. Work in one colorspace, then go to the next if required, then go to another. Don't jump back and forth. Unfortunately with some operations, multiple conversions can't be helped -- thus Avisynth comes to the rescue with cleaner methods. It's also necessary to specify whether or not the source is interlaced when making the conversion. While all this sounds rather exotic, it's been standard operating procedure for decades. All you have to do is look at some typical YouTube videos from careless users to see how a niut of sloppiness here ansd there adds up, permanently ruining output. Internet vids posted by informed users aren't nearly as ugly, despite the way YouTube techs often butcher input. The samples in post #3 are in 2 groups. In the text of the post you describe 5 sample videos of concern, but 2 of the 5 are duplicates of 1994.mkv. The other download link in post #3 has a group of 6 samples, 5 of which are the same group of 5 that you describe as specific concerns. Some of these downloads have been re-encoded as h.264 mkv's, which if you don't mind I'll have to bypass in favor of samples that haven't been lossy encoded. The sample 1-1993.avi appears three times in your posts. This is the video with audio noise. I agree with lordsmurf that retail audio software like Sound Forge is likely your best bet. You should audition a trial version for effect. Meanwhile your sample is too brief for a noise detection run that most such software would require. Visually, the sample has odd looking off-colors and skin tones due to mixed lighting sources. Overall there's a cyan imbalance from a light source off-camera to the left. You could reduce cyan (blue+green) or add red, but remember that because of lighting influences the left side of objects (as you face the video) will look cooler than objects on the right. In the next post I'll try taking on some other samples and get into processing. |
4 Attachment(s)
I elected to address some of your samples from the groups in post #1, even though some are hampered by RGB conversion. I altered the names of the samples, such as changing "1 - 1991.avi" to "1-1991.avi" by eliminating blank spaces.
The first samples I encountered were the "Hunt" tv recordings. These look like slow-speed tapes. They're soft and blurry, with low acutance and what seems like enhanced edges but no "inner" detail. For example, you can see main facial edges but facial details and other fine textures are simply blurred. I would caution that JVC and JVC clones are poor choices for playback of slow-speed sources. JVC invented VHS but never fully supported recording speeds other than SP. Panasonic would be a better choice. But some improvement could be made by working with luminance levels. Looking at luminance histograms in all of your samples it would appear that in setting up your capture levels you're apparently including black borders and head-switching noise in your analysis. This throws off histograms, especially black levels, and in making compensating settings the tendency is to contract the histogram toward the middle, adversely affecting mid-levels. Below, the top image shows a YUV histogram that includes the original borders, the head-switching noise, and some overlaid text (the latter is actually far more crisp than the image itself) and a readout of minimum and maximum YUV values. The image below that one has had the text, side borders, and switching noise removed to demonstrate how those elements affect a histogram during capture. http://www.digitalfaq.com/forum/atta...1&d=1508903594 No borders, no switching noise, no text: http://www.digitalfaq.com/forum/atta...1&d=1508903655 The histograms show some irregular spikes that indicate stretched luma values and gaps in the color response, likely partly due to the uncontrolled YUV-> RGB conversion. I used two dithering filters to "fill in the gaps" as it were, and to smooth color response, as well as to prevent block noise and hard edges in wall shadows in the background. The AVisynth script I used joins "1-100 Hunt.avi" and "2-100 Hunt.avi" into "Hunt_1and2_reworked.mp4". Sharpening soft video is really touchy. It's rarely sucessful, producing hard edges and ugly edge halos as well as a cartoon look. The color work involved expanding the darks and midtones to give the image more snap. It's difficult to sharpen videos like this without being obvious. The sharpener used was one of the best and cleanest (Avisynth's LimitedSharpenFaster with special parameter settings to avoid edge halos). The VirtualDub color and noise filters were Camcorder Color Denoise, ColorMill, and gradation curves. The settings I used are attached in the file Hunt_1and2_VirtualDub.vcf. To load filters into Virtualdub using a .vcf file, start VDub and click "File" -> then "Load processing settings...". Locate the ,vcf file and click OPEN or OK. For the .vcf to work, you must have the named filters in your VDub plugins folder. What picture mode was used on your JVC to play this video? Hopefully it wasn't Sharp (which overdoes edge enhancement) or Norm (which blurs detail and smears motion on noisy tapes). You could try playing this in Edit picture mode to see what you get. But as I say JVCs aren't so great with slow playback speeds. For the Avisynth filters used I ran QTGMC to get a partially but lightly denoised progressive video, then reinterlaced afterwards. The Avisynth script I used likely won't make much sense at this point, but here it is: Code:
v1=Avisource("E:\forum\faq\enphenate\Ahunt\1-100 Hunt.avi") |
6 Attachment(s)
1-1994.avi: heavy blue color cast and color blotches. The YUV histogram for 1-1994.avi shows an odd hard spike at the left-hand side in the white band, indicating clipping of darks that was somehow raised to a rather high black level.
http://www.digitalfaq.com/forum/atta...1&d=1508904144 Color balance is always a personal issue. With 1-1994 I elected to correct for skin tones, black tires, and white tire whitewall. Many versions of "correct" color balance are possible here, but blue tires, blue whitewalls, grayish-blue trees, and purplish skin don't compute visually, IMO. The VDub filters used wre Camcorder Color Denoise, ColorMill, and two instances of gradation curves. The filter settings are attached as 1_1994_VirtualDub.vcf. http://www.digitalfaq.com/forum/atta...1&d=1508904220 Denoising was with Avisynth's RemoveDirtMC() filter and a couple of others. The before-after image below is a 2X blowup of a thin but visible horizontal dropout (thin black line, see white arrows in top half). The dropout occupies 5 interlaced fields in frames 11, 12, and 13. There is another dropout in the left-hand trees in frame 21. There might be others but after running the script I didn't find any. http://www.digitalfaq.com/forum/atta...1&d=1508904280 This is one of many consumer videos showing that camera users don't realize how frantically sweeping camera pans can severely tax digital devices and encoders. The motion here shows excessive combing on movement, partly a function of the camera's shutter type and the fact that such motion later requires very high encoding bitrates for smooth rendering by encoders and players. I also noticed that the very top 1/5 of frames seem to have a bit of noisy mistracking "sputter". Likely unnoticeable for most viewers. A quick run with Avisynth's QTGMC smoothed much of it. As an experiment try playing "version2" of the 1-1994 mp4. It effectively drops alternate fields to get a progressive 29.97 fps video. Motion isn't as smooth, though. The avisynth script for 1_1994_Rework.mp4: Code:
AVisource("E:\forum\faq\enphenate\D1994\1-1994.avi") Code:
AVisource("E:\forum\faq\enphenate\D1994\1-1994.avi") |
2 Attachment(s)
2-1991.avi: Jerky camera motion like this makes even the best denoisers look fairelyuseless, and give encoders fits. This sort of thing didn't look too frantic on a CRT, which does a dance around whimpy LCD's when it comes to motion handling. But digital devices just see this sort of thing as so much jumpy noise.
Besides spastic motion the video has over-saturated reds and chroma shift. It's YUV histogram had a ragged color response like many of the others, but levels were in good shape. The color glitches are best addressed in the original YUV colorspace. What was available was the RGB-converted sample from post #1 that I reconverted to Lagarith YUY2. That's better than struggling with the lossy mkv encode in post #3. To steady the video at least a little you could use an Avisynth plugin called Stab(), short for "stabilizer". It steadies a video perhaps 4 or so pixels in any direction (it's better than nothing) but it should be run pretty much by itself in a separate step, after which the borders require readjustment. For a more comprehensive balancing act you can use VirtualDUb's DeShaker, which is a two-step process and which unfortunately will cost some frame real estate with really jumpy images like this. Combing on motion is a real problem with this jumpy video. That's mostly the camera shutter's fault. What I elected to do was denoise a bit witk QTGMC and use the trick of dropping alternate fields when deinterlacing. It's a shame to do this, but an uncontrolled camera with severe combing looks worse than the loss of some temporal resolution. The second denoiser was a mild RemoveDirtMC to calm the buzzing edges and red chroma noise. FixChromaBleeding, ChromaShift, aWarpSharp2, and SmoothUV repaired the color bleed and displacement. The final tweak was Camcorder Color Denoise in Virtualdub. The VirtualDub settings are attached as 1-1991_VirtualDub.vcf. There's a bad frame in frame 59. Because there's no continuous video connecting the scene change here, you can just as well delete frame 59. There are several ways to do it, but the script below shows how to create an "a" file that consists of frames 0 to 58, and a "b" video that consists of frame 60 to the end. These "a" and "b" parts are then joined together. When encoding, you'll need some hefty bitrate to render this rapid motion. Code:
AVisource("E:\forum\faq\enphenate\B1991\2-1991.avi") |
4 Attachment(s)
2-1996.avi: In this case I start with an RGB histogram. The histogram shown below is a Virtualdub ColorTools graph. Initially, a YUV histogram showed that levels were basically correct for this indoor scene -- more by luck than design, since a YUV histogram of the same scene with borders and bottom noise included just barely filled the y=16-235 spectrum. As one can see from the image below (borders and bottom noise removed), blacks are slightly elevated. If black borders were included they could be seen to hit RGB 8 at their darkest, which would show up as slightly gray on playback instead of black.
http://www.digitalfaq.com/forum/atta...1&d=1508904847 Be that as it may, the RGB histogram shows muted brights, a dominant red, suppressed greens, and even more suppressed blues whose darkest values are mildly crushed. It would seem easy enough to just boost blue a bit in YUV, but there's a problem: doing so just turns everything pink, which isn't what we want. Or one could pull back on YUV red, but that makes everything green with odd looking reddish whites. I wanted to work with each color separately and in specific value ranges, so I elected to color correct entirely in RGB. http://www.digitalfaq.com/forum/atta...1&d=1508904905 The RGB corrections were fairly aggressive. I used a pixel value reader (similar to those in "Pro" software that people pay big bucks for and then ignore, unlike the pros who use them constantly) to determine the corrections needed to make red, green, and blue look white in objects that were supposed to be white, like the bottom of the doll's feet and the baby's clothes. Then to make grays look gray, then to make blacks look black. Once that was donme, the other colors fell into place. The main VDub tool was gradation curves, tweaked with ColorMill. Some of the chroma noise, especially the discolored shadows and skin tones, were cleaned with Camcorder Color Denoise. The VDub settings I used are attached as 2-1996_VirtualDub.vcf. Before color work, I used Avisynmth to denoise with some commonly used plugins: two old standby's (RemoveDirtMC and TemporalSoften for general grunge cleaning) and a stock MDeGrain2 routine for the camera's grainy CMOS low-light noise. The MDegrain2 routine is copied pretty much verbatim from the documentation for Avisynth's MVtools plugin. There is st ill some tracking distortion in objects on the right-hand side. Looks like toe damage to me, and likely something that can't be fixed without a stronger line tbc such as a pass-thru unit. But even that might not be the solution. The final VDub output was saved as YV12 for encoding. For most projecyts I would have used Avisynth's 16-bit dithering tools to make the RGB->YUV conversion, ans smooth the histogram gaps and some hard edges -- but that technique is a story for another day. Perhaps I can get to another sample or two by tomorrow evening.... Code:
Avisource("E:\forum\faq\enphenate\E1996\2-1996.avi") |
Wow, thank you so much for the in depth posts Sanlyn. I've already read through them once and have gained valuable knowledge in regards to editing. Will definitely go through the posts multiple times until I really gain a good grasp on the techniques :congrats:
Before I begin trying to make any of the suggested edits, do you suggest I recapture all of the videos with the recommended version of huffYUV while also making sure the VCR is set to edit mode? I believe calibration was also enabled on the VCR. I made sure to crop each video before capture and to adjust the levels while viewing the histogram so that the red bleed is minimal on each side. I had no idea that the videos were in uncompressed RGB format. The original files in post #1 are the files that were created directly from the VirtualDub capture. I thought it was saving them directly from the capture to YUY2 format. Perhaps I misconfigured a setting. Will check my settings again. Thanks again, one step closer to a clean capture and restore :D |
No need to re-capture HuffyuvMT to Huffyuv. At worst, just re-encode. Both are lossless, so it should have zero impact on quality.
I don't think RGB had any effect on quality. I've not read this now-long thread, but I'm not sure how he would even capture RGB. By default, Huffy is YUV. Anyway, it's just typical home-shot video quality, with the usual terrible white balance, gamma, and levels. My own home videos look similar. I'd never set a JVC VCR to EDIT mode. That disengages the noise filters, which is a main benefit of the JVC lines. It's rare that I put it into EDIT. I know sanlyn likes it, but I'm fully opposed to it. More manual NR work will be needed in VirtualDub and/or Avisynth, and it usually corrects with the same minor drawbacks (or even sometimes worse). I'm all for quality, but take advantage of convenience when available. @sanlyn, I think some of your white balance corrections are too aggressive here. The cyan tank top (false color) was made hotter by your fix (looking at the screencap, not attached clip), and color is still false. Same for the 1996 couch. Remember that video appears somewhat darker on a computer monitor (even calibrated) than TVs. When watched, it'll wash illegal. I think a conversation hue/wb adjustment, without touching IRE/gamma/brightness correction, would do far better. Don't cook colors. Correct, but don't over-correct. |
Sometimes I rally do wish it might be possible to edit older posts. A table of comparison values from post #4 (http://www.digitalfaq.com/forum/vide...html#post51350) in this thread appears as unreadable because of my idiot typing. The original post reads as follows:
uncompressed huffyuv Lagarith Lagarith |
Yes, we have tables here! :D Uncompressed YUY2 is also possible. Some also think uncompressed means 4:4:4, which isn't true. The main takeaway here is "uncompressed" isn't necessarily locked into a spec, like codecs are, or even typical spec (ie 4:2:0 MPEG typical, 4:2:2 MPEG possible, all YV12). |
Finally have some spare time tonight to begin making some edits as well as going over all of the information in more depth :)
Few questions, Lordsmurf, you suggested that instead of recapturing the videos with correct version of Huffyuv that I should just re-encode them from RGB to YUY2. What application do you suggest I use to re-encode the files? Also, where can I find the settings that delegates if my captures are going to be RGB or YUY2? Like I mentioned previously, I had no idea that my files were being captured in RGB and not YUY2. Maybe it was due to HuffyuvMT. I am removing HuffyuvMT tonight and replacing it with Huffyuv 2.1 for my future captures. Thanks again! |
The capture colorspace can be set in VirtualDuib capture in more than one place. Look at section 3 of the advanced capturing guide at http://www.digitalfaq.com/forum/vide...html#post45238, and scroll down to the image of the dialog window for the "Capture Pin" dialog. The Capture Pin dialog is under the main menu's "Video" group. The other place you can set the intended colorspace is with the top menu's "Video" -> "Custom format..." dialog, which is pictured at the bottom of post #4 in that same settings guide. Just above that dialog box description in the same post are sample settings for Huffyuv (non-MT) and Lagarith compressors. Quote:
It's time to begin my first attempt at editing these videos :congrats: |
2 Attachment(s)
After adding some missing plugins, I managed to get the Avisynth and Virtualdub scripts up and running. I first ran the Avisynth script, then opened the virtualdub script. When I try to save the file as AVI, the process is painfully slow. Is this normal? It was running at 1.75 fps :huh1:
*EDIT* Seems like only the 100hunt video is slow. I tried saving the 1993 video as AVI after running the scripts and it was running at 8fps, still not that fast, but definitely better than 1.75fps. Heres a clip after running both scripts 100 Hunt - Restored Attachment 8004 Attachment 8005 |
Good work on the scripts ! :)
Some jobs will use different plugins and run slower or faster than others. Speed also depends on how much is running in the system altogether, and it's all very system dependent. Some video problems need industrial-strength plugins like MCTemporalDenoise or TemporalDegrain, which pretty much allow you to go out and do a little shopping while the process runs. One space and time saver: Usually when I run a script and additional VirtualDub filters are planned, I load the VBDub filters when the avs script is opened. This applies the VDub filters to the output of the script and runs both filtering tasks at the same time. When I try testing the effects of the VDUB filters on a script, I temporarily disable some of the script's lines to speed up testing (place a "#" character as the first character in a script's line to make it a comment instead of a running statement). The whole thing runs in "full processing mode", but the output is set up for YV12 color and lossless Lagarith -- after all, if the next step is final-output MPEG or h.264 encoding the result will be YV12 anyway, and VirtualDub is okay with that output method. Another way to speed up a script is to make it end early by placing a "return last" statement where you want to exit and look at results. "Return last" means to "stop here and return the results of the last thing you did.". But don't forget to later delete that line or make it a comment with a "#" as the first character -- that's what I forgot once, and ran a script for nearly an hour before I realized I was executing only a third of the script! :smack: Another quick way to get test runs going for various filters is to make a change in a script and hit F2 in VirtualDub (which is the same as clicking "Reopen video file"). Give the script a few seconds to re-run internally and it will re-open into the same frame you stopped at. Of course if you re-open often enough you'll run short of memory and will have to restart the script from scratch with "Open video file....". Another time saver is keeping a text file full of boilerplate script lines. For example, the re-interlace statement "SeparateFields().SelectEvery{4,0,3).Weave()" are tedious to type (and I almost always make a typo). But a text file full of stock statements like that offers copy-and-paste in just seconds. |
1 Attachment(s)
Slowly making progress on the captures. I found the remote for my JVC VCRs and noticed that their settings were probably not the most optimal for capturing.
So far all of my captures have been done with Huffyuv MT and these JVC HR-S7800U settings: Video Calibration: ON Picture Control: Edit Digital R3: On I think that I will recapture my important VHS tapes using the proper version of Huffyuv as well as the following settings: Video Calibration: Off Picture Control: Normal Digital R3: Off These are the video levels used in Virtualdub. They are all the default levels other than the brightness/contrast which I very slightly adjust in order to be within the histogram limits. Attachment 8008 Any thoughts? Thanks |
Looks OK, but remember that every tape is different. Settings differ according to tape, often different segments of tape. Sequences shot in backlight, frontlight, interiors, etc., will require different level settings. Home tapes vary far more than retail, which themselves aren't all that consistent.
NORM and EDIT output differently as well. NORM is softer, where you might see motion smearing from temporal filtering. Each tape will look different, too, with each mode. |
@sanlyn: What's the difference between re-encode and recompress? I don't think their is one.
@enphenate: I use VirtualDub for all lossless>lossless encoding. |
