05-20-2018, 06:32 AM
Y4BB Y4BB is offline
I capped a few hours off of a tape and the sound in the clip is throughout the entire length. What is the issue and can it be fixed?
05-20-2018, 08:28 AM
Use audacity noise reduction filter (free), take a sample of the noise first then use with those parameters (feel free to tweak all that): noise reduction: 14db, sensitivity: 3.50, frequency smoothing: 0
more infos here
You will also have to equalize the sound after that because it's very muffled, the noise residue is located somewhere around 6000 hz so careful around here
Panasonic AG-1980 audio issue - where did it go? talonhead Video Hardware Repair 19 02-04-2018 08:46 AM
Converting VHS: audio/video sync issue! myparentscloset Capture, Record, Transfer 0 12-13-2016 09:14 PM
VirtualDub Audio/Video Sync Still An Issue? JasonCA Capture, Record, Transfer 1 01-31-2013 01:05 AM
JVC HR-S7600U audio issue volksjager Capture, Record, Transfer 2 04-29-2012 10:41 AM
Help fixing the audio file issue designunlimited Restore, Filter, Improve Quality 1 04-01-2011 11:36 AM
