06-11-2018, 02:52 PM
I just got a Kramer FC-400, and noticed it has a series of "test patterns" available by using its dip switches. The users manual is very thin and doesn't have a lot of information. I've emailed Kramer Israel, but the product is discontinued.. so I don't expect much of an answer.
The reason I ask is if "pulse bar" is the same as "pulse cross" .. perhaps it overlays the Input video signal and can be used for viewing macrovision and other cp bits in the blanking area. Doses anyone have any experience with the Kramer FC-400?
06-15-2018, 01:04 AM
I could never figure it out. You'd twist knobs, press buttons, and it did nothing of value (or nothing at all).
I always treated it like a TBC-1000, meaning I plugged in input and output, and let it do the simple task of purifying a signal (mostly preventing dropped frames), and occasionally removing Macrovision for personal transfers. I didn't twiddle with stuff.
You'll find that most TBC user manuals are terrible, documenting almost nothing. Remember, this was costly broadcast gear from the 90s. Back then, a facility would order entire racks, and somebody came out to set it up and teach you what to do. So having a printed manual was seen as duplicate information, not needed. It was shortsighted and stupid, but that was what happened. .
06-15-2018, 01:00 PM
Thanks.. glad to hear at least someone else has tried.
I mostly got it because one dip switch setting adds or declines to add Pedestal (IRE +7.5) and I have a couple EH69 and EH59 dvd/hdd recorders. They expect IRE 0 and removing the Pedestal set-up at the output of the TBC should be useful.
I did hear back from Kramer Israel, they sent me the manual again, then asked what I was using it for.. or how. I mentioned to them the Pedestal control and never heard anything else. The fc-400 was a late addition to their lineup around 2006-2008 I believe, came and went quickly. It is a "format converter" for cvbs to s-video and back, hence part of the "fc-" product line. But it doesn't encode/decode between broadcast standards... so not a multicoder.
I also have a FC-4046 multicoder (both 400, 4046 were new in box).. very nice boxes but not a lot of documentation.
Kramer SP-11D built-in video detailer? Brandx Restore, Filter, Improve Quality 8 06-14-2019 09:21 AM
For Sale: Kramer SP-11D Brandx Marketplace 0 10-28-2017 11:28 AM
Any experience with Kramer scaler/switchers? schembechler Restore, Filter, Improve Quality 7 05-07-2017 11:23 AM
External proc amp, converter, TBC, Snell & Wilcox, Kramer? Mejnour General Discussion 10 01-20-2016 02:32 AM
Broadcast Grade TBC - Kramer SP-10D meson1 Restore, Filter, Improve Quality 8 06-21-2013 12:29 PM
