VirtualDub Colormill filter expanation available?
I've tried finding a description of the various functions in Colormill and can't find anything. Anyone know where to find a description?
Several of the functions are obvious, but some are not obvious to me. For example, what are the Middle Point adjustments doing? I think I know, but I'm not sure. They don't seem to operate the way I expected. An explanation of s or Real HSV would help me since I don't what this means. Thanks, Steve BTW Sanlyn, in a past post you said you didn't see any change with the sharp/smooth controls. Preprocess has a definite effect--it crashes VDub. I haven't seen any effect with the Dam H & low controls. I do see changes with the Postprocess control. It sharpens or softens an image for me. I don't use it. I just noticed the effects. |
I found an excellent answer to my own question from Sanlyn in post 18 at VideoHelp -- https://forum.videohelp.com/threads/...-as-VirtualDub
Thanks again Sanlyn :salute: Steve |
