09-25-2021, 11:49 AM
I am currently experimenting processing home video files for streaming from my computer to TV's located around my home. The original source was Video8. My files are uncompressed lossless AVI captured at 720x480 using an ATI AIW 9600 in VirtualDub. I am starting to learn AVSynth and have decided I want to create deinterlaced files using QTGMC. I also want to concurrently mask overscan in AVSynth using the method described by @sanlyn:
http://www.digitalfaq.com/forum/vide...html#post39266
He recommends using the following:
Crop(0,0,0,-8)
AddBorders(0,4,0,4)
My question is whether this operation (Crop, AddBorders) should take place before or after I deinterlace with QTGMC.
09-25-2021, 12:47 PM
Preferably de-interlace first, Cropping interlaced video can be done but make sure you crop in pairs of lines to avoid reversing the field order.
09-26-2021, 11:00 AM
Better crop before, because the black areas do not contain visible scanlines even when interlaced, and they can alter the field matching operations inside QTGMC.
Alway crop according to http://avisynth.nl/index.php/Crop
09-26-2021, 02:18 PM
Be very carfull when suggesting croping before de-interlacing because if the crop is done in odd line number or black lines added is diffrenet than the ones removed it will lead to field order reversal, That's why if de-interlacing is planned it is better done before cropping. It's a lot easier to work on a single progressive frame than 2 diffrent half frames.
The OP those crop and add border numbers are not fixed numbers they vary from tape to another, After de-interlacing use vdub2 crop filter to exactly cutomize your frame based on tape being worked on. vdub2 has a very usefull frame display tool.
09-26-2021, 03:46 PM
Do not resize interlace. Lots of people think "crop" = "crop+resize". For example, if you have 720x480 video, and crop off 2 pixels off all sides, video is now 716x476. If your new video is still 720x480, you screwed up, resized interlaced footage, and you have an uncorectable mess. That wasn't just a crop.
There's near-zero reason to crop before deinterlace.
And QTGMC, not some crappy method. (That's a given here, but just to reinforce this fact.)
09-26-2021, 04:29 PM
because if the crop is done in odd line number ...
That's why I said to follow the doc rules
... you screwed up, resized interlaced footage, ...
Yes, interlaced material should not be resized. The following works quite well
crop(crop_left,crop_top,-crop_right,-crop_bottom)
AssumeXFF()
QTGMC() # or any bob deinterlacer you like
any_progressive_filter_you_like
addborders(crop_left,crop_top,crop_right,crop_bottom)
any_resize_filter_you_like
If you wish to reinterlace back:
AssumeXFF()
SeparateFields()
Selectevery(4,0,3)
Weave()
09-28-2021, 07:15 PM
Originally Posted by lollo2
that's why i said to follow the doc rules
yes, interlaced material should not be resized. The following works quite well
assumexff()
qtgmc() # or any bob deinterlacer you like
if you wish to reinterlace back:
assumexff()
separatefields()
selectevery(4,0,3)
weave()
Wait, I don't understand your suggested code. Are you not cropping before deinterlacing with QGTMC? I thought we just concluded that we crop after deinterlacing. I was thinking:
QGTMC()
Crop (0,0,0,-8)
AddBorders (0,4,04)
I have no need to reinterlace as I am preparing this file for streaming.
09-28-2021, 07:19 PM
Absolutely planning on using QTGMC. Learning how to use it now.
09-29-2021, 03:43 AM
Crop after deinterlacing then (I do the crop before deinterlacing)
QGTMC()
Crop (0,0,0,-8)
AddBorders (0,4,04)
Perfect!
It wasn't for you but to complete the overview of processing interlaced material
The following users thank lollo2 for this useful post:
Amanjm (12-22-2021)
Thread |
Sony GV-D800 cream of the 8mm crop?
yumyum8 |
5 |
06-21-2021 08:32 PM |
VHS to compressed format, crop the edges?
Jayce72 |
14 |
06-24-2020 10:47 AM |
Crop in Virtualdub or Avisynth+?
evilt1000 |
2 |
06-17-2020 12:05 PM |
Workflow order: mask/crop then deinterlace?
rocko |
Encode, Convert for streaming |
20 |
07-31-2017 05:23 PM |
For VHS to DVD, mask (crop) before other restore filters?
Laserer |
34 |
04-09-2017 09:51 PM |
