Go Back    Forum > Digital Video > Video Project Help > Encode, Convert for streaming
07-16-2017, 08:45 AM
juhok juhok is offline
Sure. To be clear, for possible samples it doesn't matter whether I use Avisynth or VapourSynth. The results are pretty much identical.
The following users thank juhok for this useful post: rocko (07-19-2017)
09-06-2017, 04:47 PM
ragu0012 ragu0012 is offline
I may be 8 weeks behind on this thread but Rocko and I seem to be in a very similar place in our projects. i would very much love to learn Avisynth so you would hit two birds with one stone with any test scripts or other advice you give.
Have you ever tried to install Avisynth? We could feed you a script to test. You'd not be learning it alone in a vacuum.
09-07-2017, 07:41 PM
If you'd like a test lesson and a sample script, why aren' t you doing what other readers have been doing for years? Downloading sample problem videos in the capture and restoration forum posts and using the Avisynth scripts shown in those posts to fix the problems? For a more personal approach -- and even more apropo for your own work and easier than scrubbing around forever looking for relevant posts -- you could start a thread that downloads samples of your own video problems or questions. Rocko is allowed to read your threads, just as you're allowed to read his or others'. That's what a forum is for.
Or try this sequence of ancient posts from a couple years back that goes into crazy detail with Avisynth and Virtualdub for several following posts. They feature many script details, and even a sample of one of my sister's muffed videos as well as the original poster's sample problem. Starts here: http://www.digitalfaq.com/forum/vide...html#post42293 and continues into the following page.
VirtualDub and Avisynth filter help? pinheadlarry Restore, Filter, Improve Quality 46 09-17-2014 10:50 PM
Large file after using filter in Virtualdub Jasen Restore, Filter, Improve Quality 11 07-19-2014 04:17 AM
VirtualDub filter Gradation Curves Bugs.Bunny Restore, Filter, Improve Quality 1 03-04-2011 10:24 AM
Output choices on VirtualDub and Tmpgenc Steve(MS) Encode, Convert for discs 7 07-15-2010 06:59 AM
VirtualDub - advice on the filter settings deter Restore, Filter, Improve Quality 7 01-21-2010 09:54 PM
