07-07-2020, 09:03 AM
Hi
ive got a load of vhs tapes that i wish to capture lossless, cleanup then encode ive heard that some camcorders have a passtru option (svideo in to dv out) but my camcorder canon legria doesnt.
my equipment
Panasonic tbr vhs (to capture)
Legria m306 (component out and hdmi out only)
Core 2 duo laptop (to capture lossless footage, as it has firewire connection)
i7 desktop (to cleanup footage and encode)
do i need purchase another device that can take a svideo out connection from VCR to the legria camorder then from camcorder to laptop via firewire, as im unsure whats the best way.
anyhelp much appreciated
07-07-2020, 10:37 AM
Your camcorder doesn't have analog inputs and firewire output, It does have USB I guess to be used as a webcam. I haven't read the manual though, that's your task to do.
08-04-2020, 07:55 AM
thanks for the help
Ive been looking online for a camcorder with dv in so that i can connect my vcr to it to capture via passthru.
its it only SD camcorders that have dv connection, does it matter what camcorder you get panasonic, sony etc.would a 3ccd camcorder capture better than one or if a newer version of that model capture better gs120eb or gs400eb.
if anyone can suggest a camcorder as im new to this the one i have canonM306 does not
thanks
08-04-2020, 10:22 AM
That would be DV conversion, and can easily be unacceptable low quality.
Where are you? PAL or NTSC?
08-05-2020, 10:21 AM
Hi yes PAL UK
Any camcorders you could recommend
thanks
08-05-2020, 10:36 AM
PAL camcorders often had the DV in > Av out part disabled from the factory, so it can be hard to know which ones will work. Only one I've tested is a DCR-TRV 330 Digital8 camcorder, it had some line-TBCish functionality from what I remember. Those are usually quite expensive though as they're used to transfer 8mm video tapes.
If you already have a fancy VCR with TBC, I think even a mid tier capture card + alternatively a DVR or something to avoid frame drops would give you a better result for a similar price.
Thread |
PAL VCRs and capture options?
kreso05 |
6 |
12-30-2019 10:20 AM |
Which capture card among these options for VHS?
ferggue |
8 |
11-15-2019 12:48 AM |
Possible Mac capture options in 2018: Aja, Brighteye, Blackmagic?
demitri |
35 |
02-07-2019 09:46 AM |
Capture options: VHS to digital using DVD/VCR combo (dvd-VR355) and GT
threepeak |
20 |
07-25-2016 10:28 PM |
Recommended capture options with LG DR-7800?
odedia |
7 |
06-18-2016 01:50 PM |
