04-01-2021, 11:55 PM
Any opinions on the JVC HR-S5880AM?
Thanks!
04-02-2021, 10:06 AM
It should be mostly equivalent to the HR-S7800/HR-S9800 variants for playback, just without the TBC/DNR function. JVC used the same mechanism (other than the dynamic drum stuff), syscon and main video ICs in all of the svhs models in a lineup, the differences came down to other features.
It's an AM model, so it supports both PAL and proper NTSC (3.58) playback/recording.
04-02-2021, 10:14 AM
Thanks Hodgey, I have an ES-15, so the TBC won't be needed, you think? Is the DNR necessary?
I'll only be running standard VHS tapes in it, not SVHS.
04-02-2021, 11:57 AM
Yes.
But, as usual, for others who may later read this, the technicals...
ES10/15 is not a frame TBC, but strong+crippled line TBC with non-TBC frame sync. Overall, in general, the ES10/15 alone works maybe 50% of the time at most. Add the DVK as weak frame sync (setup correctly, sometimes modified), it goes up to 95%+ overall. As a line TBC, it has negative effects, but better than no line TBC at all. When used for anti-tearing, the net result is better than many VCR TBCs or no TBC.
The reason to own S-VHS units has nothing to do with the S-VHS format. The S-VHS decks tend to be some of the best VHS players made.
Opinions on For.A FA-310P TBC? ofesad Project Planning, Workflows 8 10-23-2023 06:36 PM
D-VHS vs. S-VHS VCR, opinions? Hambo2000 Videography: Cameras, TVs and Players 13 07-21-2020 09:05 PM
Converting SVHS videos and later SVHS decks Jpass9992 Capture, Record, Transfer 10 08-21-2015 02:41 PM
Panasonic AG-1980 playing non-SVHS as SVHS? cyber-junkie Videography: Cameras, TVs and Players 15 04-21-2010 03:48 PM
