VHS to digital project, build computer?
Hello everyone,
I am a newbie here in the forum and in video stuff, I would say. Even though would like to learn and make it a project and build the whole setup for VHS tape conversion for personal needs. I have read quite a lot in the forum and got an idea of what is needed, but again would be really thankful if someone could assist to build a decent (not a pro) setup, not making expensive mistakes :) Currently standing on the start line and just having some parts for PC, nothing in the workflow. I will keep updating this thread to follow the progress. Motherboard: ASRock 4CoreDual SATA2 Rev. 2.0 CPU: Intel Core 2 Duo E7600 |
Welcome. :)
That board is PCIe+AGP, so assuming you're going for ATI AIW AGP on XP here, correct? Decent CPU needed by that board. Getting the computer is only part of the battle, you also need the proper VCR>TBC for a workflow. Nothing here is a "pro" setup, nor a cheapskate setup, just a standard setup. VHS video requires good VCR (ideael is JVC S_VHS deck with line TBC, to help you avoid lots of problems later), some sort of frame TBC (an an actual aframe TBC will again avoid lots of problems and errors when trying to use it), and the good capture card (again, avoid problems). |
I read in some thread that Core2 Duo E7600 should run ok for video capture or is it still better to look for other CPU? Quote:
