Interestingly the ATI 600USB also has a linux driver available, although:
Analog audio appears to be problematic so you will likely need to employ SOX as a helper application
The root of the problem is that the em28xx presents itself as a USB audio device, and applications such as tvtime do not know to associate the video stream with the audio stream.
Components
Xceive xc3028LCQ (tuner & analog demodulator)
LG DT3303 (digital demodulator)
Texas Instruments tvp5150 (video decoder)
Empiatech em2883 (USB bridge and analog audio)
[245940.026932] em28xx: New device ATI TV Wonder 600 USB 2.0 @ 480 Mbps (0438:b002, interface 0, class 0)
[245940.027327] em28xx #0: chip ID is em2882/em2883
[245940.278601] tvp5150 9-005c: chip found @ 0xb8 (em28xx #0)
[245940.323710] tuner 9-0061: chip found @ 0xc2 (em28xx #0)
[245940.323925] xc2028 9-0061: creating new instance
[245940.323930] xc2028 9-0061: type set to XCeive xc2028/xc3028 tuner
[245941.643705] em28xx #0: Empia 202 AC97 audio processor detected
[245941.803331] tvp5150 9-005c: tvp5150am1 detected.
245942.236047] em28xx-audio.c: probing for em28x1 non standard usbaudio
[245942.236055] em28xx-audio.c: Copyright (C) 2006 Markus Rechberger
[245942.236616] Em28xx: Initialized (Em28xx Audio Extension) extension
[245942.345610] tvp5150 9-005c: i2c i/o error: rc == -19 (should be 1)
[245942.361676] tvp5150 9-005c: i2c i/o error: rc == -19 (should be 1)
[245942.380677] tvp5150 9-005c: i2c i/o error: rc == -19 (should be 1)
[245942.400677] tvp5150 9-005c: i2c i/o error: rc == -19 (should be 1)
[245942.400685] tvp5150 9-005c: *** unknown tvp0c81 chip detected.
[245942.400690] tvp5150 9-005c: *** Rom ver is 130.131
[245942.548238] tvp5150 9-005c: i2c i/o error: rc == -19 (should be 1)
[245942.614955] tvp5150 9-005c: i2c i/o error: rc == -19 (should be 1)
[245942.659213] xc2028 9-0061: type set to XCeive xc2028/xc3028 tuner
[245942.659215] em28xx #0: em28xx #0/2: xc3028 attached
[245942.659222] DVB: registering adapter 1 frontend 0 (LG Electronics LGDT3303 VSB/QAM Frontend)...
