Genesis Shipwrecked:
https://youtu.be/gnlMs3tYbnY
Opinions: This time Vevo Youtube colors are vivid but the detail is overly softened mush. They have stretched it to 16:9 so my original 4:3 is bad to compare 1:1... And my version has more halo in the bright edges. It may be the VHS player, cables are normal quality. They shouldn't cause double vision etc. Seems like a color isn't in the right spot between the black & white information. That rainbowing Cnr2 function is also used. Not using it for every video.
Again stuff. So the capture card is HP SkyHawk H789 based on Conexant and some CX23888 variable. Here is Genesis capture and conversion. This time the main functions were:
Cnr2(mode="oxx", scdthr=10.0, ln=35, lm=192, un=47, um=255, vn=47, vm=255, log=false, sceneChroma=false)
QTGMC (Preset="Slow")
TemporalDegrain2(degrainTR=2,postFFT=0)
TTempSmooth(maxr=4, strength=5, lthresh=6, cthresh=6, lmdiff=8, cmdiff=10)
dfttest(sigma=1, tbsize=1)
Slight smiley curve EQ added. Some +1.5dB <60Hz low and +1dB some highs...
