03-31-2010, 05:37 AM
manthing manthing is offline
is there an easy way to fill "bleed area"?
have attached an image.
the area in the red rectangle i did by cutting & pasting and/or by using the clone tool in photoshop.
so, is there an app that will allow me to define the area i want "stretched" and then fills the bleed area with the selection?
04-02-2010, 01:02 AM
Yeah, there will be! Say hello to the Content-Aware Fill tool in Photoshop CS5...
Get a load of this:
Are you drooling yet? I know I am -- and that doesn't happen often.
NOTE: Video at http://www.youtube.com/watch?v=NH0aEp1oDOI if the embedded FLV doesn't load for you.
Aside from that, you're left with mucking about with the clone tool, heal tool and old-fashioned selective copy/paste to build a new area.It takes a lot of time. I generally don't find it all that worthwhile, instead preferring to find a new image that works better for the purpose at hand.
04-02-2010, 03:50 AM
that sure does look kewl.
well, until CS5 comes along, i'll stick to cut&paste + clone + heal.
ho-hum.
Errors on the edges of converted VHS tapes? admin Capture, Record, Transfer 1 04-20-2012 01:24 AM
