5 Attachment(s)
The card uses NEC D64083 for Y/C separation (same as used in ADVC-300). After Y/C get separated, they are fed into Philips SAA713x as if S-Video is plugged in. Because of that I can't use Philips native drivers and thus I can't control White Peak. I have to decrease Brightness to reduce white peak. Images were obtained when I plugged my DVD player Compro VideoMate Ultra using composite. Judge for yourself. On Philips settings: Brightness 40%, Sharpness + 5. |
Now I realize that what seem to be hard to find is a respectable compatible card with windows 7 that can capture lossless AVI...it's kind of ironic. |
Premiere is an excellent non-linear editor, but I would suggest never capturing with it. Frame drops are common. Premiere is simply too much of a resource hog to leave enough system resources open for the capturing process. CPU, RAM and hard drive speeds need to be as unfettered as possible when capturing video. Premiere gobbles up most available RAM and CPU, and then it parks a huge temp file footprint on the designated hard drive. It's simply not the best tool for the task. Quote:
Furthermore, luma gain, chroma gain and IRE are often played off one another. I recall two specific eras of hardware -- the 2nd generation Panasonic DVD recorders (2003-2004) and 3rd generation LiteOn clone DVD recorders (2006) -- that reduced luminance gain in order to compensate for excessive IRE values. While reducing luma does reduce overall brightness, it can shift the image tint if done in too elementary of a method. Because luma (Y) carries green color data in YUV, these so-called "fixed" DVD recorders had green tint shifts in the shadows and blacks. I've seen other equipment that shifts red or blue. My own HDTV has a nasty blue shift (completely caused by a lamp upgrade), which is thankfully fixable due to advanced RGB controls (reduce blue gain and intensity). Nothing is perfect in the realm of video conversion, and the search for perfect hardware is only done in vain. Trust me, I've tried! Quote:
The BT8x8 (AVerTV card) is indeed quite lousy. There are a number of workaround drivers that you can play with, and get quite decent quality, but it's most definitely inferior to Philips, ATI, Hauppauge and some others. It's just not in the same league. It's comparing a cheap $25 card to cards that cost well over $100 apiece. Apples to oranges comparison. The issue I have with the Philips (AVerMedia EZMaker) is that it has halos and echos, which points to artificial sharpening. In fact, I'd bet it happens early in the processing, before the image is down-sampled internally. I don't recall that chipset's native ingest off-hand. A number of the "AVI only" type cards are made with 768x576 palettes, as opposed to the near-native NTSC/PAL resolutions of ATI. The ATI cards do not process (butcher) the video further, in terms of "adding detail" or any such nonsense, which is why they've often been referred to as "soft" when compared against cheaper cards. The biggest omission in these comparisons is that squabbling over "detail" is a wasted conversation when it concerns the capture of videotapes. None of the videos have the kind of detail information that you'll find in a test pattern. Even S-VHS, Super Beta, BetacamSP and Hi8 will have trouble pushing out pixel-accurate details to fill out a 720x480 or 720x576 Full D1 image palette. The important goal is to capture all of the image detail available, while equally NOT including random high frequency noise (which some people mistake for "detail"). The Philips and ATI cards can both do this quite adequately. While comparing against test patterns makes for interesting discussion amongst software developers, video engineers, hardware manufacturers, professional video restorers, etc -- it's mostly meaningless information to casual or even advanced users. It's not applicable knowledge of any kind, as it won't really affect what they can or cannot do with videotape conversion. Quote:
Lossless AVI (Lagarith or Huffyuv) is about 30-40GB/hour. Uncompressed YUY2/YV12 is about 75GB/hour. Lossless is about 2:1 (or 75:35 rounded to 75:37) DV is about 5:1 (or 75:13 rounded to 75:15) MPEG-2 can be whatever you make it. The benefit of MPEG-2 over DV is less colorspace compression. You can match DV 5:1 compression by using 25Mbps MPEG-2 I-frame only, or compress temporally and get it down into the 15Mbps range with similar quality. Quote:
Downloads available here: - http://www.digitalfaq.com/forum/vide...35-sclive.html - http://www.digitalfaq.com/forum/vide...-software.html Premiere is a video editor with capturing put in later as an add-on function. As such, the software is tuned to editing, not capturing. You generally want a tool built for the purpose of capturing. (Or in the case of a tool like VirtualDub, something that was built with the dual goal of capturing and processing.) You never want to use an editor or authoring software -- especially not some "all in one" solution -- as capturing is a poorly implemented add-on function in almost all cases. Quote:
Generally speaking, it's often better to just make a PAL DVD from a PAL VHS tape, and allow modern hardware to adjust the size and framerate. Software methods of conversion are permanent, while hardware improves with each successive generation. The WDTV boxes and Samsung Blu-ray players handle progressive PAL source beautifully. So a simple deinterlace is just as effective now as a framerate adjustment combined with an audio pitch edit. ... that's the long reply I've written in months. :) |
Hi guys, I tried to do a chart in my message, but was not convincing.
Here is resume of advantage and disavantages of 2 paths (DV-AVI vs AVI lossless). I did I chart in power point that I want to present to "my client" so they will decide wich way to go. Deck; JVC-HR-S7600EK (right now I have no full frame TBC) Aim: 80% VHS-PAL capture and 20% VHS-NTSC Path 1 DV-AVI Canopus ACDV-300 Advantages: Take less space Don't need to go back to windows XP. "Easy" audio/video synchro User friendly. Disavantages Recuded or no ? post-processing possibility. (ex: desinterlacing for steaming; noise reduction filter) Have to compress again to burn DVD. Path 2 Huffy-AVI ATI All wonder x600 pro PCIE Advantages: Lossless compression via huffy Post-processing possibilty (less destructive if there is plan for desinterlacing More stable format for archives 1 step compression to burn DVD More marging toward technologic evolution.* *Right now path 1 seem to suffice for their need in term of IQ result. DVD signal is carried by standard RCA connector to a Hitachi projector. Disavantages Take more space. Audio/Video synchro may be picky Many tuning to do Go back to windows XP If you find innacuracies or falses assumptions or things to add in my analysis feel free to correct me. Thanks |
Overconcern with audio sync:
Loss of audio/video sync is not really a common issue, and hasn't been for many years now. Most sync errors were caused by cheap hardware from a couple of generations ago: VIA motherboards, $10 no-name sound cards, BT8x8 video chipsets. That sort of rotten hardware just doesn't exist anymore. "1 step compression" doesn't make much sense: Both DV AV and Huffyuv AVI must be encoded to MPEG-2 to make a DVD (or AVCHD/H.264 or MPEG-2 for Blu-ray). Both are user-friendly, but... The ADVC is dummy-friendly to install and use. The ATI AIW card can be difficult to install, but it's very user-friendly to use for capturing. (Use VirtualDub for AVI.) This site has plenty of documentation regarding proper installation, setup and use of ATI AIW cards. Both methods are sound. I think your pro/con list is well-done. :) Let the workflow decide: Huffyuv is superior, but DV may be "good enough" depending on the overall workflow requirements. DV would be a lousy choice for restoration work, for example, as the colorspace compression screws up color and detail problems even more. For straight archiving of already-excellent sources, it will suffice. Certain formats look great as DV: Video8, Hi8, etc. VHS and S-VHS, however, tend to look better as non-DV. |
The only time I don't have sync problem is when I set JVC VCR to Auto mode instead of Edit, and plug audio to Tettatec sound card. Then it is indeed perfect. But every other combination gives gradual sync problem: either audio is ahead of behind. I am convinced that it has to do with a particular VCR and soundcard's clock. The gradual pattern of sync is specific for combination of a VCR and a SoundCard. Quote:
--Leonid |
The most important aspect is that you've found a workable solution. :thumb: |
First off, when I am talking about the delay it's up to (less or equal to) 80 milliseconds per hour. I.e. after one hour of capturing, my audio would be 80 milliseconds behind my video. That's what I experience using Terratec and M-Audio. It's not a big deal, but if you know it, you may notice it. If the delay over 100 milliseconds, it becomes noticeable. As to why.... Do you agree that 2 different high end sound cards have 2 different internal clock? That means that if you digitize one hour of analog audio, the length of the wav files will end up to be different up to several milliseconds. Now 2 VCRs don't run at precisely same speed as 29.97 fps. There are slight variations. One might run at 29.9669 and the other might run at 29.9701. This fact alone contributes to the difference in the length of an audio. |
--Leonid |
I almost never feed capture cards composite signals anymore. Even if the VCR is composite out, another device in the loop will switch it over to s-video. That's usually a second JVC S-VHS VCR, as needed. I have a dozen of them, after all.
Definitely post that Avisynth script in another thread. Maybe we can help you tweak it. :) For the PAL, what I'm getting at is that you just need to convert PAL to progressive. PAL interlaced and progressive are both 25fps, so it's an easy task, using a good Avisynth deinterlacer like QTGMC. Even YadifMod+NNEDI2 can yield decent results for non-animation, if you're in a rush or on a low-power CPU computer. I don't see a need to double frame rates. I don't even own a DVD player anymore, which doesn't come with USB capable of supporting MPEG-4 (Divx/Xvid, sometimes H.264 as MP4/MKV), supporting PAL and NTSC. All of them play region-free (homemade) PAL DVDs. |
If I follow you DV capture come with 4:1:1 color space, meaning that if I capture good PAL-VHS tape (4:2:0) I am loosing some color "potential" quality. Happy new year! |
- PAL DV = 4:2:0 = colorspace similar to DVD/Blu-ray discs 4:2:0 (but not 1:1 identical, since co-siting method is different) For PAL, DV is not as big of an issue. It's still best to leave it as 4:2:2, however, until that very last processing encode (for distribution online, on disc, broadcasting, etc). - 4:4:4 exceeds most sources (all but film, 2K/4K digital) - 4:2:2 is ideal - 4:2:0 is acceptable - 4:1:1 is noticeably lossy - 3:1:1 is excellent, used in some Sony proprietary formats (similar to 4:2:2 ratio) An analog tape (PAL, NTSC or SECAM) is closest to 4:2:2 when measured with that digital measurement. Quote:
Can we says that PAL-DV vs PAL-huffy, is the same as comparing picture vs photo strip?
I tried to find "Image" to vulgarize for my "old" client. :) |
I don't think I quite understand the question. I think you're getting at the old photographer cliche: picture vs photograph.
Is that correct? If so, then I don't think it's really quite that bad. But it's probably close enough to serve for the purpose of comparison for a layman (the client). |
I mean Film negatives vs photos or in a mordern way....RAW vs JPG :) |
Funny that it's called lossless, lossless vs what? I mean if it's lossless what is the point of using YUV 4:2:2 uncompressed? :confused:
Quite interesting...(I know better digital photography and not much video)...I guess that huffy is just a way to save space then... Regards |
I don't work with Premier. But I think working with Huffyuv avi directly there should be fine.
