Originally Posted by Mejnour
Useless? No, not entirely.
The AVT-8710/CTB-100 proc amp abilities are maybe 10% of a real TBC. If you only need a mild little tweak, it will work.
Of course, you generally need more than a mild little tweak, when the source is problematic enough to merit work. Also, colors can meander and change over the course of the workflow, when VHS source is involved. It has to be interpreted and mutates a bit as it's passed through capture hardware and filter hardware. That's one reason 4:1:1 DV is so harmful to NTSC video, because it obliterates half of the color data immediately. Minor little tweaks tend to get lost between the proc amp and the final video. Nuanced color work is best left for the software editor (NLE), just prior to mezzanine archiving, which serves as the source for distribution encoding.
