01-11-2012, 10:02 PM
Mejnour Mejnour is offline
Hi again,
realizing that eventually I may be asked for my project to convert PAL to NTSC, should I apply the same logic as for filters i.e. do it before the capture with a converter
01-11-2012, 10:36 PM
Leave it as PAL. Those converters do a pretty lousy job at PAL<>NTSC conversions. Such a conversion in real time isn't easy to do "good", thats why Snell and Wilcox Alchemist standards converters go for six figures. Convert to NTSC right before compression for your target media (eg: DVD).
The following users thank NJRoadfan for this useful post: kpmedia (01-16-2012), Mejnour (01-13-2012)
01-12-2012, 02:37 PM
metaleonid metaleonid is offline
Originally Posted by Mejnour View Post
Hi again,
You do filters before capture because you capture in lossy DV. Otherwise you would've done capture -> filters -> PAL to NTSC. Now that you need to do conversion, you either do:
filters -> capture -> PAL to NTSC
or
Try both and see which one you like better.
Do not do PAL to NTSC prior to capture.
--Leonid
The following users thank metaleonid for this useful post: Mejnour (01-13-2012)
01-16-2012, 03:29 AM
Correct:
Hardware filters > capture > PAL to NTSC conversion
Capture > software filters > PAL to NTSC conversion
Or better yet:
Hardware filters > capture > software filters > PAL to NTSC conversion
In fact, you can often leaves PAL as PAL and NTSC as NTSC. The reasons to convert disappear more and more each years.
Many NTSC players now play PAL, because of universal manufacturing practices.
PAL players always played PAL as PAL-60.
Streaming videos are format agnostic, no comprehension of "PAL" or "NTSC".
In fact, all digital video is now standardized luma/chroma, with only framerate determining format. The analog era is gone.
Various AVISynth scripts to clean noise and convert PAL to NTSC metaleonid Restore, Filter, Improve Quality 12 01-09-2012 07:49 PM
Convert NTSC to PAL and back to NTSC ? admin Capture, Record, Transfer 0 07-24-2010 08:29 PM
PAL vs NTSC, which one to use in my workflow? lordsmurf Project Planning, Workflows 0 03-25-2010 07:39 PM
Hardware Workflow Update Kenneth M Project Planning, Workflows 8 07-19-2009 01:36 PM
DVD project workflow help, SLP VHS to DVD Superstar Project Planning, Workflows 4 02-27-2009 10:30 AM
