DVD project workflow help, SLP VHS to DVD
I'll need guides for MPEG Video Wizard, SoundForge, GoldWave, BeSweet & BeLight, all for how I'd use them in my workflow.
Thanks a lot. |
I don't need a guide for 6, only because I don't have PhotoShop. I also don't need any guides for 7 or 8 because I've done those two steps hundreds of times. :)
I'll try out step 2, and let you know how that works out. Thanks a lot for writing such an in depth, helpful guide for me. I really appreciate it. |
I'm curious what your authored DVDs look like, using DVD-Lab, from an aesthetical quality stance. If they're really good, maybe I could convince you to try your hand at writing a guide?
That's one piece of software that just bothers me, seems to be overly difficult. Guides that make DVD-Lab easy would be most welcome. While there are guides online, none of them would qualify as "make it easy" in my book. |
I've actually considered it before when I made DVDs constantly and was very proficient using it. The only thing on my authored DVD that I don't like is I use a picture of the video as the background on the main menu and you have to stretch the picture out to fit the screen, and it distorts it very much. I've thought maybe PhotoShop might help, but I don't have that. But yes, I'd consider writing a guide for it.
