Quantcast A Warning On Lagarith - digitalFAQ Forum
09-06-2017, 05:21 PM
dinkleberg dinkleberg is offline
I have seen Lagarith's use mentioned dozens of times not just in the forums, but in the guides as well.
Lagarith cannot ever be recommended for archival or editing purposes. Using Lagarith at any point in the workflow is irresponsible and reckless at best. Video-corrupting errors have existed in nearly every revision of this encoder. This is not just conjecture, this is by the developer's own admission. Imagine the bugs we don't know about!!
These are just the most recent three such fatal flaws. Viewing the changelog there are over a dozen such instances. This is simply unacceptable by any measure.
Version 1.3.27 released on 12-08-2011
Restored a table entry in the Fibonacci coder I accidently deleted; this would cause video corruption or crashes when playing back high-resolution video.
Version 1.3.26 released on 09-25-2011
Fixed an error that caused certain solid color frames from 1.3.20 and earlier to be corrupted.
Version 1.3.24 released on 4-10-2011
Fixed a bug in the SSE & MMX median restoration routines for RGB video that caused corrupted video.
Suggested alternatives to Lagarith include: UT Video, HuffYUV, MagicYUV. It is possible there are more, but as far as I can tell these are the best / most popular.
Further reading:
https://lags.leetcode.net/Changes.html
http://camstudio.org/forum/discussio...any-way-to-fix
https://mod16.org/hurfdurf/?p=142
The following users thank dinkleberg for this useful post: bever (09-11-2017)
09-11-2017, 11:25 AM
bever bever is offline
Thanks Dinkleberg
Will take heed or at least be wary of lagarith. You present a compelling argument with the three reference links
hadnt progressed past HuffYUV yet anyway for lossless compression and was not on the to do list yet as storage is so cheap and I dont do a HUGE amount of tapes.
09-11-2017, 12:04 PM
Haven't had any problems, and I can testify to that after thousands of hours (yes, thousands) of processing. Gwet the latest version, you're set to go. I also don't use thosse nutty softwre pacages that users say they have in the links. Only a sucker would pay premium prices for the second-rate NLE's, and they have plenty of other problems with third-party codecs and add-ons (those poblems include all versions of huffyuv, which gives some editors fits).
Best capture format for master VHS-to-digital? (Huffyuv vs Lagarith vs MPEG) rocko Capture, Record, Transfer 10 09-06-2018 11:20 PM
Paypal SHA-256 warning with cPanel and WordPress DAP? via Email or PM Website and Server Troubleshooting 1 09-13-2015 04:34 AM
Convert HuffYUV to lagarith without loss? hysteriah Edit Video, Audio 8 08-16-2015 12:52 PM
HuffYUV/Lagarith YUY2 not working with VirtualDub/Premiere? hysteriah Project Planning, Workflows 17 03-22-2015 06:54 AM
