Plesk sent me a scary-looking email today, warning that my sites would be taken offline in 10 days!
Subject: <server.kp.tld> Domain event notification: The period of validity is about to expire.
Message:
The validity period of domain 's.org', owned by user account 'admin' (Contact name 'kp') is about to expire.
The domain and all of its services will be deactivated by Oct 2, 2011 unless the validity period is prolonged.
The validity period of domain 'l.com', owned by user account 'admin' (Contact name 'kp') is about to expire.
The validity period of domain 'd.net', owned by user account 'admin' (Contact name 'kp') is about to expire.
The validity period of domain 'c.com', owned by user account 'admin' (Contact name 'kp') is about to expire.
Almost exactly one year ago, I migrated these four domains to a new server at
EuroVPS. It seems that the migration process did not migrate the longevity settings of the domain, instead using the Plesk default of one year. Since these are all my domains (and not domains of clients), the expiration should be set to "never".
This is really easy to fix in Plesk.
NOTE: These images/instructions were performed in Plesk 9.x, and should work the same on both Windows and Plesk.
Note: You must be logged in to view images. Either login or register now (it's free!). Your email is not sold, we don't spam.
Step 1 - Login to Plesk.
Step 2 - Go to the Domains page. You can get to the domains page either by using the navbar menu on the left side of the Plesk interface (if present), or by clicking on the domains text/icon on the main Plesk homepage.
Step 3 - Select your domain.
Step 4 - Visit the Resource Usage page. The Resource Usage text/icon is about halfway down the page on most Plesk templates, underneath Mail (email account setup) and Files (file manager, password protection, etc).
Step 5 - Set to new date, or to 'Never Expires'. Tick the Never Expires box, and the entire date option will become grayed out. Optionally, you can simply select a new date. (Since these are my sites, again, I set to never expire. The only way these sites should go down is if I decide to take them online on my own. Not likely.)
... And that's it.
IMPORTANT: Do you have a good host?!
See if they rank on our top 10 list:
http://www.digitalfaq.com/forum/web-...-best-web.html
If you want to run a successful website, you need a high quality host.
