Closed Thread
12-18-2014, 05:31 PM
msingle msingle is offline
I have been installing sites on my new StableHost account and I have repeatedly run into annoying security issues.
For example, this morning when logging into a site for the first time I got a "too many WP-Logins message". I waited a few minutes and hit refresh then I got a "flood protection" error because there were too many requests from a single IP address or something like that.
So I tried to log into another site (each site is on its own account) and got the same flood protection error.
I can understand the need for security. But this is almost as bad as the reason I left my previous host of 10+ years. I can't seem to get any work done - you know like write content, finish setups, upgrade WP, etc. for all the error messages.
Anyone else have this issue with StableHost? If this is the way they are, I'll have to move again. I was afraid of this uncertainty and the possibility of having to go host hopping after having such a good experience at my previous host for such a long time until recently.
Support told me that they have a 10 login limit from the same IP address in a 3 minute window.
My way of working is to have several browsers open at the same time and so I can see that this may cause the problem.
I'll try to figure out how to adjust my multitasking and see if I can eliminate the problem without it driving me crazy in the process.
12-18-2014, 07:10 PM
What you probably encountered was Varnish.
There is a new Varnish plugin in beta right now, and I think they're using it. If I remember, I'll ask the owner about it this weekend. Personally, I think 10 per 180s is a bit too strict, so hopefully they'll be adjusting it.
Realize that having Varnish is a good thing -- assuming this is what it is.
It could also be mod_security, but I don't think so given the error messages. It sounds like Varnish rate limiting.
12-18-2014, 07:41 PM
I know they use Varnish because at the beginning they rebooted it so that I could get in and the error messages say they are Varnish.
But one tech said it was mod security.
Closed Thread
Wordpress Security Starter Guide Brent Website and Server Troubleshooting 1 08-27-2013 01:02 AM
Does WordPress have a security hole? via Email or PM Web Hosting 1 07-25-2013 07:20 PM
VHS to DVD, Going crazy, running out of time scameron Capture, Record, Transfer 15 01-19-2010 07:38 PM
