Change sticky color in vBulletin themes
This is confirmed to work on vBulletin versions 3.6 to 3.8.2
adapted from "Different Cell Color for Stickies" by Andrew111888 @ vB.org The information there had some typos, so this fixed it First, you need to change the threadbit template:
Find the following line: PHP Code:
PHP Code:
Use an online color picker, if you need help selecting a color: http://www.colorpicker.com And now your STICKIES have a different color from other posts, helps them pop out more, not get lost amongst the other forum posts. To "uninstall" this mod, simply remove the above code. Note that the original code was retained inside of mark-out code: PHP Code:
1 Attachment(s)
Example of mod in use:
Attachment 634 Simple gray was used here, but it could have just as easily been pink or blue or something else. |
To match the new styling of the site, it's been changed to a pale yellow color as of today.
