01-27-2010, 11:22 PM
admin admin is online now
This is confirmed to work on vBulletin versions 3.6 to 3.8.2
adapted from "Different Cell Color for Stickies" by Andrew111888 @ vB.org
The information there had some typos, so this fixed it
First, you need to change the threadbit template:
  • In AdminCP
    • Styles & Templates
      • Style Manager
        • your theme
          • Edit Templates
            • threadbit
Find the following line:
PHP Code:
<td class="alt1" id="td_threadtitle_$thread[realthreadid]title="$thread[preview]"
and replace it with the following:
PHP Code:
<!-- // <td class="alt1" id="td_threadtitle_$thread[realthreadid]" title="$thread[preview]"> // -->
<if condition="$thread['sticky'] == 1">
td class="stickybg" id="td_threadtitle_$thread[realthreadid]title="$thread[preview]">
<else />
td class="alt1" id="td_threadtitle_$thread[realthreadid]title="$thread[preview]">
</if>
And now you need to add some CSS
  • In AdminCP
      • Style Manager
        • your theme
          • Main CSS
            • Additional CSS Definitions (bottom of page)
Add the following code to the bottom of the "additional CSS" window:
.stickybg { background-color: #COLOR; color: #000000; }
and replace COLOR with the HEX code for the color you want.
Use an online color picker, if you need help selecting a color: http://www.colorpicker.com
And now your STICKIES have a different color from other posts, helps them pop out more, not get lost amongst the other forum posts.
To "uninstall" this mod, simply remove the above code. Note that the original code was retained inside of mark-out code:
PHP Code:
01-27-2010, 11:30 PM
Example of mod in use:
Simple gray was used here, but it could have just as easily been pink or blue or something else.
07-13-2010, 02:22 PM
To match the new styling of the site, it's been changed to a pale yellow color as of today.
Quality vBulletin themes for only $4 admin Web Development, Design 1 07-25-2013 07:06 PM
WordPress themes library (by style), free and premium designs admin Web Development, Design 4 03-04-2013 02:19 PM
About the 2009 analog change (DTV, HDTV) Tranzor Videography: Cameras, TVs and Players 5 06-25-2008 12:28 PM
Anybody here know how to change your IP address? wayshway Computers 15 06-26-2006 11:13 PM
Color Question wheezer210 Restore, Filter, Improve Quality 2 04-18-2006 03:19 PM
