Windows 10 keeps getting stuck on loading!
Hello, buddies. What's up? I want to start off by saying that I'm new to this forum and that this is also my first post. I'm not sure if this is the appropriate location. But I had hoped to get some better advice from you. Guys, I have a problem Windows 10 keeps getting stuck on loading. After several tries, I gave it my best shot, but the problem remained. I'm not an expert in this area, so I'm asking you for advice in this regard. Can you perhaps assist me?
Standard issues apply
- bad recent install of drivers/software - bad shutdown, resulting in corrupted drivers/OS - bad spot on HDD/SSD, resulting in corrupted driver/OS - bad RAM - bad power supply - bad CPU ... in that order. Solutions include: - uninstall software, safe mode may be required - reinstall drivers - repair OS - replace bad hardware Repairing OS install is always the iffy issue, not fun, may not work correctly or at all. So reinstalling OS required. Always backup your data. That includes not just another HDD, DVDs, cloud, etc, but printed paper copies. |
Thanks for replying, and the suggestions also. Already I fixed it, but I don't know if they fix or not, but the issue is gone after applying the method mentioned here, found after searching on Google. I just performed the system restore process. Thank you.
