-   Author, Make Menus, Slideshows, Burn (https://www.digitalfaq.com/forum/dvd-menus/)
-   -   Misc advice on using DVD-Lab Pro v2 (https://www.digitalfaq.com/forum/dvd-menus/3395-misc-advice-dvd.html)
lordsmurf 08-20-2011 09:08 PM
Archiving a PM conversation, in case it helps others...
RE: jeanpave - button question
basically this person wanted to have an invisible button on the menu, that becomes highlighted as you navigate to it. but, he not only wanted the highlight on the button, he also wanted the button detail to show through.
long explaination -
imagine a normal button, that has some texture on it. a normal button, when navigated to, will place a highlight over the button, but will also show the button and the texture on the button.
now if the user wants a "normal invisible" button, then you won't see anything on the screen until you navigate to that button, and then when you get to that button, you will only see the highlight, ie an outline shape of the underlying object, but you cannot see the texture on that object.
i think this is normal behaviour for all dvd authoring software. however, if you know otherwise, especially with dvd workshop 2, then please let jeanpave know. i already explained the above to jeanpave. told him to either go for a normal button, or live with the highlight only option, or have a text with a "invisible highlight" option next to / underneath the text.
ok?
Thanks. :thumb:
