-   Author, Make Menus, Slideshows, Burn (https://www.digitalfaq.com/forum/dvd-menus/)
-   -   Menu help, or photoshop (https://www.digitalfaq.com/forum/dvd-menus/534-menu-photoshop.html)
angelofanimes 07-26-2005 05:15 PM
menu help, or photoshop
http://www.digitalfaq.com/forum/imag...endsmenu-1.jpg
How do you make the small curve in it? That LS has used in this menu. I'm not Photoshop expert, so I wasn't sure of the aligning abilities if there is one.
lordsmurf 07-26-2005 05:31 PM
4 Attachment(s)
Basically, a big round brush with the shape of the curve you want. And a canvas that is way too big, temporarily.
Some image to illustrate:
Attachment 448
To make larger canvas, goto IMAGE and CANVAS SIZE and make it a lot bigger.
Attachment 451
Then make the brush size you want, if one does not already exist. A single click of the mouse is all you'll need to plop down the circle of ink.
Attachment 450
You want to make it on a new layer.
Then make the the layer on top of the old one.
Attachment 449
Then re-crop the full image so your old canvas is there at the right size of 720x540.
Make sense? Have to be brief, really busy here.
markatisu 07-26-2005 06:59 PM
Neat thats how I made the Aladdin menu, I figured it was the ghetto way but I guess that other people think the same
I did not want as strong a curve (using LS version but exact same concept as my original just better fonts and placement of items
http://www.digitalfaq.com/forum/imag...ddinmenu-1.jpg
