-   Author, Make Menus, Slideshows, Burn (https://www.digitalfaq.com/forum/dvd-menus/)
-   -   Menu sneak peak, re-authoring a DVD (https://www.digitalfaq.com/forum/dvd-menus/727-menu-sneak-peak.html)
wheezer210 02-04-2006 02:58 PM
This is the menu I created in anticipation of re-authoring a dvd ...menu impressions?
The black pentagram in the middle of the flames will be a motion menu of that episode.
cp32 02-05-2006 01:28 PM
Nice, I would put your signature at the bottom . Under Dsc 1 [88]:D .
Are you using philips method for custom thumbnails? I would
Yours , but would also add some shadow to your pentegrams. The Red will be stand out enough.
You dont want it to look UnGodly.. Or Do You ? [}:)]
