-   Author, Make Menus, Slideshows, Burn (https://www.digitalfaq.com/forum/dvd-menus/)
-   -   Making DVDs-software question! (https://www.digitalfaq.com/forum/dvd-menus/909-making-dvds-software.html)
MagnificentMarcus 08-30-2006 04:24 AM
What does everyone use when it comes to editing and making menus on DVDs that they have created or recorded? I think I'm ready to make the big jump from just using my DVD recorder for simple thumbnail menus and editing.
Please, I'm looking for simple programs to get started on.[8D]:D[8D]:)
padre2 08-30-2006 04:58 AM
I like TDA Pro, works for me - you can do simple menus or pretty complex ones if you want.
MagnificentMarcus 08-30-2006 05:25 AM
Can you edit DVDs too?
ninjastriker 08-30-2006 05:53 AM
I would personally recommend using these -
dvd decrypter - rips the files from your dvd to save on your hard drive
mpeg - vcr - edit the episode and save as a mpeg
dvd workshop 2 - create menus and burn the disc.
Those are the three main ones i use to create my sets. they are all simple to use and very efective.
LS has info on how to use them on his site - http://www.digitalfaq.com/
lordsmurf 08-30-2006 06:32 AM
What curtis says.
For some more info on this, Marcus, e-mail me.
markatisu 08-30-2006 06:52 AM
I agree, I would use either TDA or Ulead to start off, then once you have figured out how to do the whole setup you can start using Photoshop and things like Adobe Premiere to make the DVD's more professional (if you want to, its not for everyone due to the time and headaches involved)
padre2 08-30-2006 07:14 AM
You can 'extract' video/audio content from dvds to create new ones - but you really can't 'edit' a dvd.
markatisu 08-30-2006 07:34 AM
You also dont want to use TDA (if you are using TDA) to try and cut out commercials, while it can be done successfully due to the method in which TDA edits you often can have bits of commercials left in.
MPGVCR is probably the fastest and most detailed editor around. Its the ONLY reason I still have my PC because everything else I can do on my Mac but edit (until I get a Mac that runs Windows lol)
padre2 08-30-2006 08:19 AM
Yeah, TDA is a lousy MPEG2 editor. Use MPGVCR or VideoReDo to trim your commercials before bringing them into TDA. They are frame-accurate editors.
cp32 08-31-2006 02:03 AM
I use whatever works on my pc lmao! I use Vegas for more visual effects . Also encodes audio to 5.1 surround LOL.
Ulead for more professional feel. TDA for my lazy moods lol
Basicly whatever runs on my ancient pos . Thats what I use cookie lol
MagnificentMarcus 09-05-2006 12:17 PM
Thanks guys! You have really been a lot of help.I hope to be able to show you what I've been working on soon. The menus look pretty decent, except I have to get the font right.
