-   Blank Media (https://www.digitalfaq.com/forum/media/)
-   -   Liteon 5005 failed - DVD tray won't open anymore (https://www.digitalfaq.com/forum/media/338-liteon-5005-failed.html)
Digitaldvdman 12-29-2008 09:07 PM
Hi,
I have two Liteon 5005 units. Both were working great for years with the "hack" Mr. Wizzard wrote and which installed seamlessly with no flaws! Good on him!
But now one unit seems to have decided that it won't open the DVD tray anymore; just goes "clunk" and won't open.
The other will open and close ok, but won't "load" just tries and after a long time "fails". Any suggestions?
admin 01-13-2009 04:39 AM
6 Attachment(s)
As per e-mail...
The reply:
The motor in the DVD drive may be gummed up, or the internal plastics may have shifted just enough to block it from coming out. It's a mechanical issue of some kind. I'd dismantel the machine, and see if the DVD drive will eject with the top and face removed.
Follow-up e-mail:
Thanks, I will re-disassemble it. Tried that already but had trouble
getting the front face plate off. Will try harder. How about the other one that just "fails" any ideas on that one?
Follow-up reply:
The drive with the load fail probably has a drive that is mechanically sound, but the laser itself is either too dirty or dead. You can attempt to clean it. Don't use a "cleaner" device, take the drive apart. The drive may be dead, meaning it has to be replaced by another compatible drive. For these machines, you'll probably need an older LiteOn drive. Do you smoke? Optical electronics develop "lung cancer" and die very early. Optical electronics in the home of smokers have extremely limited lifespans.
And the requested "how to clean a DVD drive" image-based guide:
Attachment 21
Remove the drive from the computer, and unscrew the cover of the drive. Note that you may have to break the warranty seal (but seriously, who cares?).
Attachment 17
With the drive unscrewed, start to dismantle it by sliding the various pieces around, removing removal parts.
Attachment 18
Look for foreign matter, such as dust in the drive, which could be the entire cause of your problems. Computers are magnets for dust, and that includes your drive. A can of compressed air ("duster") may be good here, but be sure it does not spew liquid propellant. Hitting the laser eye with this liquid often kills it permanently, as the chemical tends to destroy the optical coatings. Cheap ones from OfficeMax tend to spew liquid, while better ones from Fry's and Microcenter do not.
Attachment 16
Get yourself some alcohol. It needs to be denatured alcohol, or at very least 70% or better (70-100%) isopropyl alcohol, commonly sold as "rubbing alcohol" in drugstores. Please watch for the isopropyl % as many of them are 50% or less, and you don't want those.
Attachment 20
Get a good non-cotton swab and lightly soak one end in the alcohol. The photo above is a Q-Tip, a "cotton swab" -- you DO NOT WANT THESE. Using a cotton swab could scratch or otherwise damage the eye. Non-cotton swabs are also often sold at the drug store, near cotton swabs. Electronics stores (Fry's and Microcenter, for example) usually have non-cotton cleaning swabs too. Don't let a salesman sell you their other cleaning products (mostly overpriced junk), however.
Attachment 19
Find the laser eye, and gently swipe the lens once or twice. If it does not dry instantly, you can turn the swab around and very gently swipe the lens dry once. Looking at the eye, there should be no residues on the majority of the lens starting from the center (optics often has build-up around the very edges, this doesn't matter as much, it's been there since manufacture most likely).
You're done. Put the drive back. If it works better, your cleaning helped. If this did not help, you have other issues. The drive may simply be dead.
Remember that optical electronics have limited lifespans, calculated in thousands of hours (a 4-digit number), sometimes less. The whole recorder is not dead, just the burner drive inside.
lucyndavey 09-25-2009 01:48 AM
hi there. i have a lvw 5006 that sometimes does this.a quick tap above the drive draw releases the draw.this is caused by the drive belt in the dvd drive getting slack due to old age.
admin 09-25-2009 01:56 AM
You know, my Pioneer 111 computer burner started doing this same thing last month. I have to tap the drive tray to get it back in. If I did not tap it in, and let it sit there for too long, I bet the motor would give out.
But that's a "load" function issue, the "eject" function is more controlled by the teeth in the drive. I don't know that the clunk experienced by the first poster would be fixed with a new belt. It's really nothing more than a thick black rubber band.
Thanks for sharing your input! Welcome to the forum. :)
lucyndavey 09-26-2009 01:42 AM
thankyou for the welcome.the draw on mine also sticks when loading in too so you have to give it a shove which i forgot to mention lol.:rolleyes:not all of the drives are belt drive though which i found out as i have a spare duff dvd drive that i was going to rob the drive belt out of but it was cog driven.:(
admin 09-28-2009 03:34 AM
The belts can range in size and thickness, too!
