-   Blank Media (https://www.digitalfaq.com/forum/media/)
-   -   Which DVD media should I buy in Brazil? (https://www.digitalfaq.com/forum/media/6016-dvd-media-buy.html)
gamemaniaco 08-02-2014 11:07 AM
What are the best DVD media I can find In Brazil? I look for DVD media of the highest quality and high durability and resistance
I do not want to be worried about moisture and heat in DVD media so I look tough DVD here in Brazil
admin 08-03-2014 06:44 PM
What's available?
And not just in stores, but online. (I assume you can buy online in Brazil, yes?)
gamemaniaco 08-04-2014 08:18 AM
I do not know what are the best DVD media that I can buy here in Brazil, in my town I only find philips dvd, smartbuy, nipponic etc but I can buy in Brazilian websites but I do not know these sites and do not know what are the medias best dvd dl dvd and I can find here in Brazil and ask for help
can someone help me with this doubt?
volksjager 08-16-2014 12:22 PM
Mitsubishi-verbatium - buy it online - you can get it on ebay if all else fails
http://www.ebay.com/itm/NEW-Verbatim...item2a4209f8f5
gamemaniaco 08-16-2014 12:26 PM
1 This is the best media? is heat resistant and is resistant to moisture?
2 I wanted to buy the media here in Brazil, I know not to buy this media from another country and do not know how much this cost media in Brazilian currency
volksjager 08-16-2014 12:29 PM
this is the absolute best media.
you will have to do your own research on where to buy it within your country as i dont think we have many members from Brazil.
just make sure it is the one i linked to - NOT the "life series"
gamemaniaco 08-16-2014 12:35 PM
these here are original and good?
http://www.fnac.pt/Verbatim-DVD-R-4-...namento/a84596
http://www.lepok.com.br/produtos.php?cod=93084
volksjager 08-16-2014 12:54 PM
yes - both of those a good.
gamemaniaco 08-16-2014 12:58 PM
what is verbatim medias top the other media? what verbatim medias have to have heat resistance and moisture resistance?
dvd verbatim has resistance to heat and humidity? which differences of verbatim medias for other media from other brands?
sanlyn 08-17-2014 10:59 AM
Yes. Better than other brands.
It doesn't matter. No one recommends other brands.
gamemaniaco 08-17-2014 11:44 AM
which differences of verbatim medias for other media from other brands?verbatim dvd media is made by CMC Magnetics
help my questions
lordsmurf 08-24-2014 09:12 AM
We've already given you all the answers we can.
gamemaniaco 08-24-2014 09:14 AM
I wanted to know more about verbatim, it is Japanese? what level of quality and it is the verbatim discs have resistance to heat and humidity
lordsmurf 08-24-2014 09:19 AM
No. It never was.
MCC/MKM media comes from:
- Singapore, the main Mitsubishi owned facility
- Tawain, from the CMC plant (but it is NOT CMC media!). Also formerly the Prodisc plant.
- UAE (United Arab Emirates), from the FTI (Falcon Tech) plant, Again, NOT FTI media!
- India was also a former location, at the MBI (Moser Baer) plant. I think they were dumped due to heavy QC issues.
The same as any other disc. Avoid heat and humidity.
gamemaniaco 08-24-2014 09:22 AM
1 to cmc manufactures for verbatim? you guys said it was bad cmc
2 mitsui mam- a and taiyo are good and the medias?
lordsmurf 08-24-2014 09:25 AM
It's just real estate. MCC makes the disc at the CMC plant. Those plants probably aren't cheap to make, hence the renting of space. CMC makes CMC discs, MCC makes MCC discs. But at the CMC plant.
Mitsui (MAM-A, MAM-E) is terrible.
Taiyo Yuden is excellent as well. Both it and Verbatim (Mitsubishi) are excellent choices. As long as it's not fake.
gamemaniaco 08-24-2014 09:33 AM
1 mitsui mam to this on the same level of bad cmc philips?
2 one philips 16x dvd cmc mag.01 can have a life span of 10 years?
reply my questions please
kpmedia 08-27-2014 08:23 AM
MAM-A and CMC are both junk.
CMC lifespans tend to be fine. It;s getting the initial quality burn that's at issue.
Stop asking us to reply after only 1-2 days. You're just a Free Member -- not a Premium Member or a client.
We'll get to it when we get to it. :knock:
gamemaniaco 08-27-2014 02:32 PM
a disk philips dvd + r 16x will have a life span of many years to keep the burned files? id: cmc mag m01
