bin and cue to dvd?
does anyone know how to convert bin and cue files to dvd format.
thanks |
BIN is a data file.
CUE is the file that tells a burning program how to read the BIN. Open NERO, open the BIN/CUE combo, and burn the disc. You can't do anything else with it. |
you can extract the video from it with a prog.. vcd gear
