1 Attachment(s)
Hi Everyone.
want to ask about audio L/R for Karaoke. i'm new useing TAW4 and i'm trying to make a dvd karaoke with TAW4. and i having a problem with left and right audio. when i played in stimulation everythings ok. but when i burn it, i can't switch L/R audio through dvd player remote. i have to back to menu screen and choose the audio 1 or 2. then so far my suggestion is, i dont have stream audio channel. all i got is audio track and it make me can't switch the audio L/R from dvd player remote. anyone can help me ? i attach some picture Thanks __________ EDIT: i just try to add the channel audio, and check it again from VLC. but when i burn it, still no L/R in dvd player help me someone.... :depressed: |
Are you sure the DVD player allow left-only or right-only audio? Most do not.
1 Attachment(s)
thanks for the replay KPmedia.
in dvd player i have to switch the sound through dvd menu. can't switch it from L/R remote dvd player |
I've never seen DVD authoring software that instructed the video to play only L or R channels in the menu. I've only seen players that physically can select the audio channels.
It usually needs to be multi-track authored, not L and R separate. If I were you, I'd use TMPGEnc Authoring Works, and then do a two-channel audio video. For one, that's going to be complaint to the DVD specs, and work on all players. |
in karaoke vcd we can switch the audio (on/off the voice) channel L/R button through remote. right ?
2 days ago i burn karaoke dvd, and to on/off the voice i have to press language button. can i make my karaoke dvd works like vcd ? Thx |
The multi-language DVD authoring idea is a good one. :salute:
It may use VCD -- you'll just have to burn one and test it. Some DVD players play VCD, some do not.
