06-04-2023, 05:43 AM
grandmair grandmair is offline
I have a simple beginners question on this subject. I have a similar old panasonic vcr (nv-f65, nv-f77 etc) How to disconnect one board ( it does not matter - audio, video etc) from the main psb? Are they soldered or is it ok just to pull it out? Just affraid to pull it if its glued or soldered to the main pcb. Thanks in advance!
06-04-2023, 06:53 AM
pics attached
06-04-2023, 07:14 AM
looks to me like its soldered
06-04-2023, 02:45 PM
The video sub-board was soldered on my NV-F77 at least, didn't touch the hi-fi audio one but looks like it's also soldered in. They also put Surface mount electrolytic capacitors on a hybrid IC that was soldered on to that again so it was a bit of a pain to swap them.
The following users thank hodgey for this useful post: lordsmurf (06-06-2023)
06-04-2023, 03:12 PM
Thanks! Will try to desolder it
06-04-2023, 05:17 PM
Those are soldered headers, there is two types, streight and angeled, In your case angeled, They have to be de-soldered, Use suction iron or solder wick braided copper wire with flux to clean old solder first.
The following users thank latreche34 for this useful post: lordsmurf (06-06-2023)
06-06-2023, 11:49 AM
thank you!
Panasonic AG1970 chroma board recap? brandonpaterno Video Hardware Repair 5 06-14-2022 06:21 PM
Wanted: Panasonic AG1970 chroma board/card brandonpaterno Marketplace 0 06-14-2022 03:00 AM
AIW HD Daughter Board ? CapsuleJ Capture, Record, Transfer 0 10-20-2018 01:05 AM
Panasonic AG-1980P Y/C board recap? (replaced capacitors) x77x Video Hardware Repair 14 10-21-2015 04:35 PM
Pull backups vs. push backups from production server via Email or PM Web Hosting 1 07-25-2013 07:18 PM
