09-11-2024, 02:02 PM
descotes descotes is offline
Hi,
I had downloaded Virtualdub a few months back and it was working swimmingly. Then all of the sudden yesterday it stopped working. After redownloading and after a few error message I just finally got it to work.
I downloaded this - VirtualDub 1.9.11 + Filters.rar
I'm so happy that it's finally working that I'm afraid to mess with it. However, I wanted to also use this with it - HuffYUV.rar
So I put a Virtualdub folder within my C:\Program Files folder. I downloaded the HuffYUV.rar and it's in my downloads area. I extracted it and I see a folder called HuffYUV in my downloads with a huffyuv.inf file in it.
I tried to right-click and install the file where it was at and I got a "Copy Error". It says:
Setup cannot copy the file HUFFYUV.DLL
Ensure that the location specified below is correct or change it and insert "Huffyuv AVI lossless video codec in the drive you specify.
Copy files from: (and it asks me for a file or I can browse
Not sure - Do I right-click and install the file from there or put the ".inf" file in the Virtualdub folder that I made or do it from my Downloads folder?
Thank you for any assistance
09-11-2024, 02:27 PM
Use the hofmand installer.
https://github.com/hofmand/video-codec-installers
09-11-2024, 06:10 PM
facp facp is offline
Are you on Windows 7 and above? Watch and follow the instructions on this video. It worked for me.
https://youtu.be/1vpr4MOB5mk?si=w0KPasfC-O7JeZbd
09-11-2024, 07:09 PM
Gary34 Gary34 is offline
https://www.digitalfaq.com/forum/vid...y-install.html
https://www.digitalfaq.com/forum/vid...e-huffyuv.html
VirtualDub with HuffYUV outputting in RGB? HomeVideoProject Capture, Record, Transfer 1 12-23-2023 09:39 AM
Huffyuv installed in Win10, but can't run QTGMC? ThumperStrauss Encode, Convert for streaming 21 07-24-2023 08:25 PM
ATI MMC vs. VirtualDub, Huffyuv? Pinnacle vs ATI? SinghDk Capture, Record, Transfer 11 05-02-2015 04:07 AM
Installed a codec pack, and it doesn't appear in VirtualDub? someonewhy Encode, Convert for discs 4 01-15-2013 11:18 PM
