03-27-2026, 05:52 PM
Chocomilkmotel Chocomilkmotel is offline
Hey y'all! Long time lurker, first time poster! Basically just have a question regarding recording onto VHS. Long story short I have an interlaced video that I'll be recording from my laptop onto tape and was wondering if it was better to deinterlace said video via virtualdub or handbrake beforehand or if deinterlacing first was the way to go. I usually deinterlace all my VHS capture footage but that's always just for archiving footage, not necessarily dubbing to tape. Thanks!
Disregard, idk why I didn't think of it before. I recorded 10 seconds of interlaced video and 10 seconds of deinterlaced footage onto a tape and the interlaced stuff looked better. The more ya know lol
03-28-2026, 08:31 AM
Welcome.
What is the output device? Something embedded in the laptop?
What software did you use to record out?
I find that a DV converters are a decent bridge, but I'm making mental notes of other methods.
Yes, retaining the interlace is ideal. Methods that force deinterlace are lower quality.
03-28-2026, 10:29 AM
Hey Smurf, thanks!
So my usual workflow is basically record with AmarecTV with an Elgato capture device -> drop that file in Virtualdub -> Neat Video Noise Reduction -> Deinterlace -> levels -> resize to 720x960 -> crop, then bounce that file out to AVI via lagarath codec, then just bounce that file to MP4 via Handbrake.
03-30-2026, 12:49 PM
VHS is inherently interlaced, so you might as well keep it interlaced all the way through, rather than going through an unnecessary de-interlacing and re-interlacing scheme. (Unless you're playing special tricks, like using the two fields to store separate images, such as what the 3D VHS camcorders and Japanese-market "record two programs simultaneously" VCRs did.)
Captured VHS footage is already deinterlaced? jojoe2122 Capture, Record, Transfer 11 07-11-2022 04:08 AM
Color flickering on deinterlaced VHS capture? thunderbirds93 Restore, Filter, Improve Quality 6 02-22-2021 04:08 AM
Best way to convert MPEG2 to deinterlaced MP4 on PC? jnielsen Restore, Filter, Improve Quality 37 08-31-2017 07:15 PM
Capture interlaced, but how to to keep video interlaced when making DVDs? premiumcapture Encode, Convert for discs 11 12-21-2013 03:40 PM
Interlaced vs. non-interlaced artifacts? via Email or PM Capture, Record, Transfer 1 04-16-2009 05:37 PM
