11-04-2013, 11:51 AM
Mejnour Mejnour is offline
Just wanna share my experience,
I had 30 U-matic tapes to convert. I had the chance to put my hand on a good U-Matic Sony VO-9800.
To use the VHS s-video equivalent I had to use DSP transcoder (DSP-295) that have the infamous special 7-pin connector.
My experience was flawless. So far the best IQ that I have seen on a tape.
I use the 7-pin connector but it seem that you can use some homemade engineering to separate the luma and chroma signal. (link below)
Set-up for capture
11-05-2013, 12:45 AM
Do you still have the deck?
How much was it?
The main reason we never touched U-matic was because (1) almost zero demand per year, (2) afraid of having to repair yet more decks.
11-06-2013, 08:14 PM
Hi
Yes still have it.
If I remember it was around 50$. Imagine the $$$ for postal transport, this beast weight 77 lbs, fortunatly I got it from a local classified ads.
True U-matic is more pro broadcast oriented and have been remplaced by betacam in the 80'.
Transfer or capture DV tape? GreenAcres Capture, Record, Transfer 8 11-30-2012 03:12 PM
Problem with SECAM VHS playback / tape capture monks19 Capture, Record, Transfer 4 03-04-2012 10:04 PM
Anyone have experience with discontinued ACE GTH electronics ? Mejnour Restore, Filter, Improve Quality 5 01-16-2012 07:38 AM
Severe drag or picture across top of VHS tape capture Sparrowhawk Capture, Record, Transfer 1 03-04-2011 04:14 PM
VHS tape malfunction, mechanism not rolling tape properly admin Capture, Record, Transfer 0 10-12-2009 10:57 PM
