05-28-2004, 12:42 AM
lantern lantern is offline
I have looked through many of the forums at videohelp.com and haven't found a definative answer. I was wondering what the optimum resolution for capture is through a digital cable receiver. I normally capture regular cable channels at half-D1 and am happy with the quality. I just got digital cable and have been trying to get the settings down for capture. Should I just stick with half D1 or should I go with something more along the lines of 640x480?
05-29-2004, 06:02 AM
For AVI capture, I prefer to stick to 4:3 ratio 640x480 just because it's easier to edit that way, and it's higher than the source res anyway.
For direct MPEG capture, depends on the channel. They all vary. From Cartoon Network, SciFi or a local, I can grab 352x480 and not miss anything. On a PPV channel, I can sometimes see a slight loss of definition (but not much) when doing Half D1. For those, it's better to go Full D1 to capture every detail. However, I'm not that picky too often.
I suggest test captures, and then see what you like. Most people cannot see the difference between Half D1 and Full D1 unless they have perfect vision, a huge tv, and stand 6 inches from the screen.
Digital cable = the new svcd format Tranzor Videography: Cameras, TVs and Players 5 07-06-2008 05:19 PM
Digital cable reception bad, due to converter box ? mlaviolette Capture, Record, Transfer 1 12-21-2006 02:18 PM
AIW MMC resolution 384x288? (ATI All In Wonder) lookouts Capture, Record, Transfer 21 03-15-2006 10:57 AM
ATI MMC and 704/720 resolution thoughts? admin Capture, Record, Transfer 0 02-15-2005 09:19 AM
Capturing Digital Cable with ATI AIW card JimGorsline Capture, Record, Transfer 1 07-08-2004 12:58 AM
